graememk
posted on 19/5/06 at 02:28 PM |
indy square meets round
ok bodywork, my indy for some reason the square back pannel meets the round arch used to be flush but now it sticks out a bit and its now bonded and
rivited on, what have other people done to make it fit flush again, i'm sure mr SVA might have a prob with mine.
stevec
posted on 19/5/06 at 02:33 PM |
I saw some at stoneliegh that had very neat aluminium plates folded around the dodgy join.
And one that had been filed to blend in and painted.
Steve.
PAUL FISHER
posted on 19/5/06 at 02:59 PM |
Take a look at "Hellfires" webb site,they have used a aluminium shaped plate,to neatly finish it off,if I recall there are some pictures
of it on there site.
posted on 19/5/06 at 03:28 PM |
Indeed - they are in rebuild 21st June 2005
HERE
[Edited on 19-5-06 by Hellfire]
graememk
posted on 19/5/06 at 03:42 PM |
thats an idea hellfire, did you have another plate behind that one or just the one on top.
stevec
posted on 19/5/06 at 04:01 PM |
Thats what I spotted at Stoneliegh.
[Edited on 19/5/06 by stevec]
posted on 19/5/06 at 05:09 PM |
Just the plate on top. It's all pretty solid underneath.
Howlor
posted on 19/5/06 at 08:02 PM |
What I did with mine on my MNR was to fill the back of the joint with resin so it was a stable solid joint then carefully filled the gap with gel
coat. Some careful rubbing down then polished to a gloss finish to match the rest of the body with 2 grades of compound. Although you can see the
joint due to the difference in shape either side it looks very neat.
steve
