Nick Davison
posted on 14/4/03 at 07:49 PM |
Exhaust pipe manufacture
Can anyone help me with a company capable of making a stainless exhaust system for a turbo, one big pipe, in the Lincoln/Peterborough area.
Nick
Rorty
posted on 15/4/03 at 01:34 AM |
Do a search on this list using my name. I posted a few exhaust builders details a while ago. One of them may be convenient to you.
Cheers, Rorty.
Billywhizz
posted on 15/4/03 at 06:27 PM |
Nick
If you have a welder I could supply you with the stainless steel bends for you to weld up yourself.
Bill
Nick Davison
posted on 15/4/03 at 07:36 PM |
That's tempting Bill but I don't think my welding is up to stainless steel standards and I only have co2 gas!
Thanks all the same.
Nick
paulf
posted on 15/4/03 at 08:28 PM |
It is possible to weld stainless with an arc welder if you have one. I have just made a 50mm downpipe from 1,5 mm tube and premade 45 and 90 degree
bends.I used some 1.5mm stainless rods and about 70 amps current.
Paul.
Nick
paulbeyer
posted on 15/4/03 at 09:44 PM |
Hi Bill,
Can you supply enough bits to make a 4 into 1 system for a pinto engine?
7 out of 10 people suffer with hemorrhoids. Does that mean the other 3 enjoy them?
Billywhizz
posted on 16/4/03 at 06:28 PM |
yep no problem, just make a list of what bends and stuff you need and email it to me.
Bill
Nick Davison
posted on 16/4/03 at 07:38 PM |
Paul
I only have access to a mig welder and CO2 but I have loads of decent 0.8mm stainless wire. I have welded with this on about 20swg sheet. It worked
but looke crap and was probably not particularly sound either. Is it possible to get a good weld with this set up?
Nick
Viper
posted on 16/4/03 at 07:48 PM |
Paul
Nick
Basicaly the answer would be no mig on stainless allways looks naff but with co2 you are flogging a dead horse, you realy should be using pure
argon and for the best results you realy should TIG the item...as far as exhaust manifolds go if you want the manifold to work for you then it should
be built by someone who realy knows there stuff a poorly designed manifold can rob you of horsepower..
Nick Davison
posted on 16/4/03 at 08:04 PM |
Thats about what I thought.
I only need a simple single 2.5 - 3 inch pipe with a 4 bolt square flange to the turbo outlet so it will be straight forward enough. But Iwill still
get someone who knows what they are doing to do it.
Nick
paulbeyer
posted on 16/4/03 at 09:40 PM |
Nick,
I wouldn't know the first thing about welding so I'm glad Viper stepped in and answered your question.
My Dad has been a welder for 40 years and would be able to TIG weld a stainless steel exhaust together for me no problem. He has made me a smart roll
bar which he bent out of 316 grade stainless but when it comes to making an exhaust he doesn't have the means to make the bit where 4 pipes
merge into one.
CairB
posted on 16/4/03 at 09:46 PM |
Paul,
Regarding the bit where the pipes join, I've done a few by making a filler plate that is welded on the end of the pipes. Then make a cone that
is then welded on the pipes and the filler plate. Any help?
Colin
