MkIndy7
posted on 20/5/06 at 06:40 PM |
Induction kits
Following on from the filters and Ram pipes thread...
Has anybody any experience with their effects between different brands other than their sound?
Are K&N for £80 so much better than the universal £35 Halfords cone filter for example?
Are the more expencive induction kits worth the money or are they just well over priced for boy racers?
If there worth the money then i'll spend it.. but otherwise i don't like getting ripped off! ![](/images//smilies/mad.gif)
BKLOCO
posted on 20/5/06 at 06:54 PM |
If you have a liking of Burberry and all things chav then spend loads of dosh on an induction kit that will do bugger all for your otherwise standard
production car other than wee off the neighbours.
If however you just want to supply your engine with cool clean filtered air buy a bog standard universal filter.
![](/images//smilies/bigsmile.gif) ![](/images//smilies/bigsmile.gif) ![](/images//smilies/bigsmile.gif)
flak monkey
posted on 20/5/06 at 06:58 PM |
They just help by allowing you to place the inlet so you can get cool air to it. Not usually a problem on a locost with the carbs sticking out of the
bonnet. However if you have FI you might want to think about the best position!
I know someone who bolted a Max Power induction kit to their 2 litre astra and it gave them an extra 20bhp... *cough*bollocks*cough* ![](/images//smilies/bigsmile.gif)
Sera
http://www.motosera.com
MkIndy7
posted on 20/5/06 at 07:02 PM |
Yeh thought the Chav references would come out ,
Its for an engine conversion where there is no standard airbox and I doubt the one from the donor would fit.
Was just wondering if anybody had experience of the different brands from a performance point of view, rolling road, racing, personal preference
etc
Basically I don't want to put a cheepo filter on if its going to hamper the engine breathing.
[Edited on 20/5/06 by MkIndy7]
gazza285
posted on 20/5/06 at 07:30 PM |
Do what I do and don't use filters. As a plus I get to rebuild my engine more often too.
skydivepaul
posted on 20/5/06 at 09:11 PM |
As always you get what you pay for. K&N have been in the business for years long before the max power brigade came around so you cant go wrong
with a K&N filter but you will pay the price. some other companies have tried to copy K&N and some work better than others. I personally tried
pipercross and K&N on twin 40's and the pipercross was shite. very restrictive, the K&N performed virtually the same as with open
trumpets but without the costly engine rebuilds.
................beware of shiny plastic chrome copy cone filters that are priced accordingly![](/images//smilies/bigsmile.gif) ![](/images//smilies/bigsmile.gif) ![](/images//smilies/bigsmile.gif)
http://www.smartideasuk.com
http://www.smartmapping.co.uk
HD CCTV
IP security systems
access control systems
jay taylor
posted on 21/5/06 at 05:48 PM |
i would also have to mention the fact that some universal filters cannot be cleaned but you can get cleaning kits for k&n and pipercross also you
could try emailing them and asking them power increase on the engine you are using
TangoMan
posted on 21/5/06 at 08:57 PM |
Measured airfow
I seem to remember from my racing days that someone had flowbenched various filters.
K&N came out on top with very little effect on airflow. Is some cases it was found to be better than an open carb due to holding the stand-off.
Foam filters (Pipercross etc) showed a slight restriction when dry and slightly more when oiled. They tested a cheapo pancake filter for a laugh and
as you can probably guess, it was crap!!
I can't remember the model but interestingly a new standard filter was as good as a foam one but deteriated quicker as it became clogged.
The K&N flowed significantly better than everything else when clogged.
I guess the moral is of you use a standard filter, change it regularly.
OH yeah, and sock filters flowed worse than a standard paper element.
I would be nervous of buying anything from Halfrauds with a performance label. OK for boy racers but I bet they have never been tested and are
unlikely to be a good as something which has been developed over many years with a racing pedigree.
Bear in mind that most will flow sufficient for part throttle so you are only likely to see any benefits at WOT and fairly high revs.
DIY Si
posted on 21/5/06 at 09:03 PM |
I'd always buy K&N. They have a 1,000,000 mile/10 year gaurantee. AS said, they can be cleaned and re-oiled so you'll only ever need
one. Depending upon application, they can increase air flow over a standard open carb, and flow just as much air when 'clogged' with
1/4" of dust. The dirtier they get, the better they filter too, but without the usual drop in air flow.
MkIndy7
posted on 21/5/06 at 09:51 PM |
Hmm, there more like the responces I was hopeing for, thanks guys.
Then only thing making me weary of K&N's is i've heard there not that good when you have an Alow Flow Meter in the system (Its for a
XE engine BTW), Has anybody heard the same or is it another wild roumor?
Although that maybe ties in with what TangoMan said about only seeing the benefits at WOT and fairly high revs as the AFM set up is allegedly a bit
slow to react.
