mackei23b
posted on 22/5/06 at 09:32 AM |
ZX9R Engine Bolt Sizes
Hi there
I'm just about to make up a cradle for the engine, its a C1 model. I'd be grateful if you could confirm the bolt diameters / lenghts and
where you got them from.
Many thaks
Ian
schnelle bak
posted on 22/5/06 at 12:27 PM |
Hi there
I,m to are building a MK Indy with a zx9 engine, only MK delivered the engine mounts, I will take some pics this evening from the mount and look at
the size bolts i'm gonna use.
Steef
russbost
posted on 22/5/06 at 04:20 PM |
Believe they are identical to the ZX10, in whichcase the bolts at the front are aroun 3" long, the rear ones are a very long bolt, I'd
guess about 10", one of mine had seized in the frame & had to be cut, I replaced it with a length of studding.
All diameters are 10mm
