Mezzz
posted on 22/5/06 at 11:25 AM |
Amp draw
Any one know how many amps a MIG welder draws?
phelpsa
posted on 22/5/06 at 11:33 AM |
Depends on the welder!
My Clarke 151e turbo on full power draws just enough to blow a 13amp fuse
RazMan
posted on 22/5/06 at 11:42 AM |
My SIP 130 Turbo must be on the verge of blowing a 13 amp fuse - and it makes the house lights flicker like crazy
Raz
NS Dev
posted on 22/5/06 at 11:44 AM |
hmmm, my new machine draws 52 Amps
On a more helpful note, you can get away with running up to a 200amp mig from a normal 13 amp socket, as long as you are prepared to change the fuse
every now and again when working at full whack.
That's what I do with my 210 amp machine (actually I substitute the fuse with something less likely to blow when working at full power, the
whole circuit is protected by a breaker anyway.)
NS Dev
posted on 22/5/06 at 11:46 AM |
Prob not, as above I run a 200amp machine no probs.
The light flicker is probably more to do with a very long spur to where you plug the machine in, coupled with undersized cable feeding it.
flak monkey
posted on 22/5/06 at 12:03 PM |
Depends what power setting you are using the welder at and what the open circuit voltage is.
Sera
http://www.motosera.com
ned
posted on 22/5/06 at 01:43 PM |
on full whack my clarke 160t is yet to blow a fuse on a 13amp plug...
beware, I've got yellow skin
posted on 22/5/06 at 04:20 PM |
My Sip 150 will trip a 16 amp MCB but dosen't blow 16 amp fuse wire or the 13 amp fuse in the plug ---- it only takes above 13 amp for an
instant as the arc is first struck.
[Edited on 22/5/06 by britishtrident]
rusty
posted on 22/5/06 at 05:01 PM |
If you need more power wire direct from your fuse board it is not a dig deal I mean loads of peps have 11.5KW showers and they need 50 odd amps
posted on 22/5/06 at 05:13 PM |
Hmmm... firstly, how does it hold the pencil??
BKLOCO
posted on 22/5/06 at 06:52 PM |
coozer.
You have a very convoluted mind
