benson68
posted on 25/5/06 at 09:09 PM |
Bike Carbs Again
Hi
I am gonna start looking for some bike carbs for my 1600 pinto with a 2lt injection head fitted
Is there anything to look out for?
Do the carbs end up having to be dyno jetted?
Which Carbs are the easyist to modify / replace the jets etc
I know some jets cost the earth
Manifold is no problem
jonno
posted on 25/5/06 at 09:11 PM |
ask or do a search for andyharding ![](/images//smilies/wink.gif)
andyharding
posted on 25/5/06 at 10:05 PM |
Ooh I'm famous!
DarrenW
posted on 25/5/06 at 11:24 PM |
ets are easy - you can drill them out. Dynojet needles are more expensive.
Manifold is most expensive bit but you have that covered.
Are you fitting megajolt? Bike carbs dont allow easy vac advance connection to dizzy. If you are going megajolt then some carbs have TPS ready fitted
which is nice (eg R1).
Im fitting bike carbs to 2.0 pinto and opted for ZZr1100 Keihins (38mm choke). Maybe smaller choke will be better for 1600.
Ian Pearson
posted on 26/5/06 at 12:58 PM |
"Manifold is no problem"
Are you making your own manifold?
tim windmill
posted on 26/5/06 at 02:36 PM |
oliwb has bike carbs fitted to a 1600 pinto,
we have got zx9 carbs fitted to our 2.0l pinto with 40mm chokes
jacko
posted on 26/5/06 at 02:40 PM |
HI I used kawasaki zx9r - e1 bike carbs they have TPS fitted . I made my own manifold have a look in my archaves Jacko![](/images//smilies/bigsmile.gif)
benson68
posted on 26/5/06 at 04:24 PM |
Ian - yes gonna make my own manifold
Fabricate one offs for a living so it shouldn't be a problem
Was planning to use the electronic dizzy just to keep the cost down
Heres the numpty question what does
ets stand for in the world of carbs
Anyone know how to get over the dizzy vacum problem
andyharding
posted on 26/5/06 at 07:05 PM |
Des Hammel says with the pinto dizzy just take a vacuum off one of the manifold runners and it will be fine.
I didn't buy that so I'm modding the dizzy to remove the vacuum advance and give a better curve etc.
garage19
posted on 27/5/06 at 07:05 AM |
I built an engine with 38mm gsxr carbs on a pinto. The dizzy got in the way so we ditched it in favour of a megajolt.
givemethebighammer
posted on 28/5/06 at 07:35 AM |
Only the pilot jets are expensive (about £5-7 each). The weber DGV/DGAS main jets fit the Kehin carbs (Kawaski, Honda) and they're only £1.60
each from http://www.fastroadcars.co.uk . They may fit other stuff too. To be honest the pilot jets that come in the carbs should be OK. If not I have
a couple of spare sets of 35+38 pilots to fit the kehin carbs you can have cheap.
for reference
CBR600 - Kehin VP: 36-38 pilot jet
CBR900 - Kehin VP: 40 pilot jet
CBR1100 - Kehin VP: 42 pilot jet
All for late carb model bikes, don't worry too much about the pilot jet size, my 2.0L zetec runs on 42 pilots with 1.5 turns out on the mixture
screw, but it will run on 40's with 2.5 to 3 turns out. You don't want to go much more that 4 turns out on the screw though.
Link to ebay jets:
http://cgi.ebay.co.uk/WEBER-DGV-DGAS-MAIN-JETS-NEW-SIZES-90-TO-205_W0QQitemZ8068849217QQcategoryZ122139QQrdZ1QQcmdZViewItem
[Edited on 28/5/06 by givemethebighammer]
benson68
posted on 28/5/06 at 08:35 PM |
Thanks for that
So it looks like I need a set of CBR600 Carbs!
