Author: Subject: Supercharger fitted but erratic idle
Monkeybasher
posted on 28/5/06 at 04:48 PM Reply With Quote
I have fitted my supercharger to a 2.0l zetec. and plumbed it all up but it has a very erratic idle. with the throttle fully shut it still idles at 1000rpm- 1700rpm rather than stalling. I have checked for leaks without any joy.
My setup goes
throttle valve
short pipe
eaton m45 supercharger
couple of silicon pipes
chargecooler
inlet manifold with MAP comming from it
injectors
engine
running on megasquirt ECU. Do I need an idle stabilisation thingy and how do they work, or have I missed something. The thing I dont understand is with the throttle closed where is the engine getting air to run from?
Any ideas?
theconrodkid
posted on 28/5/06 at 04:56 PM Reply With Quote
have you got an idle controll valve?
who cares who wins
pass the pork pies
Monkeybasher
posted on 28/5/06 at 04:59 PM Reply With Quote
Nope
How do they work, I know of them but thats about it. I never had one on throttle bodies or carbs, is it just forced induction that need them.
RazMan
posted on 28/5/06 at 05:12 PM Reply With Quote
I think I'm right but don't quote me
The idle control valve has an independent air intake, usually plumbed into the intake pipe behind the air filter. It completely bypasses the throttle body and produces a stable tickover.
Looks like you might be wanting one then
Raz
the_fbi
posted on 28/5/06 at 06:07 PM Reply With Quote
XE's run an ICV and they aren't forced induction so may not be that.
Is your FPR running with a vacuum connection into the charged part of the system.
Fuel pressure is proportional to boost, although on a NA car clearly this doesn't change, so you'll need to check how its plumbed in as standard, it may need modifying to allow for the larger amount of air getting in.
Does the charger have a clutch on it? ie. at idle is it actually producing any boost at all?
What map are you running on the MS? One for a standard Zetec or a S/C one?
Dale
posted on 28/5/06 at 06:14 PM Reply With Quote
If your idle control valve intake is on the non presurized side it would make a difference I would think.
Could be wrong- I have to hook one up to mine since I have up sized my throtle body.
Dale
Dale
my 14 and11 year old boys 22
and 19 now want to drive but have to be 25 before insurance will allow. Finally on the road
Monkeybasher
posted on 28/5/06 at 06:16 PM Reply With Quote
The fuel pressure reg(off a probe) is attached to a vacuum line on the inlet manifold
The supercharger is not clutched to my knowledge, so is producing boost all the time.
I'm am running the same map as what I was running with throttle bodies. I thought this would be good enough to get my going.
the_fbi
posted on 28/5/06 at 06:30 PM Reply With Quote
OK, so the S/C is running all the time, sticking in more air and also more fuel due to the higher fuel pressure.
You running any lambda input to the MS? Or do you have any lambda gauge etc?
Is the tps setup OK so MS knows the car is at idle and not partially open throttle?
Lambda would be good to know to see if your map is close given the S/C and different fuel pressure.
Is the engine speed steady with a fixed throttle position?
Monkeybasher
posted on 28/5/06 at 06:52 PM Reply With Quote
hi,
the lambda gauge is reading lean. But I wouldnt have thought it would cause this erratic idle. Looking at megatune the revs are actually going from 800rpm up to nearly 3000rpm and smoothly no coughing or backfiring and a nice whirlingg noise from the charger
I'm not using tps i'm using MAP although the tps is wired in and working in the real time display. I think its only used for clear flood mode. Maybe I should be running tps instead of map, i dunno.
Monkeybasher
posted on 28/5/06 at 06:54 PM Reply With Quote
....oh and I cant seem to get a smooth idle at any rpm.
theconrodkid
posted on 28/5/06 at 08:19 PM Reply With Quote
ive never dealt with a blown engine before but idle valves are always moving and keeping idle stable,not having one is prob the problem.
it by-passes the completley closed throttle plate
who cares who wins
pass the pork pies
Monkeybasher
posted on 28/5/06 at 08:22 PM Reply With Quote
So are these idle valves ECU controlled then. Do I need to get one off another car and wire it into megasquirt?
APR
posted on 28/5/06 at 08:26 PM Reply With Quote
is there any pics of the setup
RazMan
posted on 28/5/06 at 08:41 PM Reply With Quote
My ECU has an input connected to the ICV so I guess yes.
Raz
stevebubs
posted on 28/5/06 at 09:03 PM Reply With Quote
Monkeybasher,
Any pics you can share??
theconrodkid
posted on 28/5/06 at 09:11 PM Reply With Quote
they are ecu controlled,i have some ford ones laying around i think if your stuck
who cares who wins
pass the pork pies
posted on 28/5/06 at 10:44 PM Reply With Quote
If you don't have an idle valve, and the engine continues to run with a completely closed throttle then you must have an air leak somewhere.
Dusty
posted on 28/5/06 at 11:43 PM Reply With Quote
I think in amongst folder I got with my ECU it said boosted engines were best run on TPS at idle switching to map when you open the throttle.
the_fbi
posted on 28/5/06 at 11:55 PM Reply With Quote
My LET certainly runs from the TPS @ idle
[Edited on 28/5/06 by the_fbi]
FiredragonCT
posted on 29/5/06 at 10:50 AM Reply With Quote
Personally it soulds like a leak on the vacuum side - but might also be due to the fact that the TPS has been disconnected from the system and MAP settings have changed due to the charger running from idle.
So I would start by looking for leakson the vacuum side and re-calibrating the MAP sensor. Alternatively try running both MAP and TPS - this should give smoothest ride and best fuel economy - not sure if the Megasquirt system allows this kind of setup?
Alsomaybe consider changing to MAFsensor in stead of MAP - if you can only do MAP or TPS or MAF, then MAF is my preferred setup.
Hope it helps some
Zaine Louw
Chairman
www.teamdragon.co.za
Monkeybasher
posted on 29/5/06 at 11:54 AM Reply With Quote
oops
After checking, double checking and checking again all my pipes/plumbing for leaks as everybody keeps saying it must be a leak including myself, guess what, it was (the echo of "I told you so rings out" ) . I'm feeling a bit embarrased, but relieved. The leak I never noticed was a hole on the actual supercharger, not sure what its there for. I plugged this and theres a shock it ran so much better. It was still crap revving up so added lots more fuel and its getting lots better. Time for a coffee then back out.
Thanks everybody and stop shaking your heads.
I will post pictures tonight.
[Edited on 29/5/06 by Monkeybasher]
the_fbi
posted on 29/5/06 at 12:06 PM Reply With Quote
May be an idea to find out what its there for at some point too
