<<  1    2  >>
Author: Subject: SOD the hacksaw!!!
robertst
posted on 30/5/06 at 11:43 AM Reply With Quote
SOD the hacksaw!!!
angle grinder, 300mm dia. disk, 2000watts, one tube per second! whole chassis and more in a couple of minutes
and only for 19 quid
BRING IT ON!
yeah!
[Edited on 30/5/06 by robertst]
[Edited on 30/5/06 by robertst] Rescued attachment grinder.jpg
Tom
robertst
posted on 30/5/06 at 11:44 AM Reply With Quote
Tom
flak monkey
posted on 30/5/06 at 11:49 AM Reply With Quote
Watch your fingers. And dont put anything you value under it when cutting. Just you wait until it grabs for the first time
Sera
http://www.motosera.com
robertst
posted on 30/5/06 at 11:55 AM Reply With Quote
also bought a kevlar jockstrap just in case for the delicate family jewels.
Tom
Hicko
posted on 30/5/06 at 11:59 AM Reply With Quote
sorry to be boring but always wear a full face mask when using a 9" grinder I saw a lad have one jump at him causing a 6" cut in his chin, use but with respect.
James
posted on 30/5/06 at 12:15 PM Reply With Quote
Originally posted by Hicko
sorry to be boring but always wear a full face mask .
And thick gloves/welding gauntlets.
Unless you fancy a finger that looks like Calvin's!
And ear-defenders too if you've any sense!
James
DarrenW
posted on 30/5/06 at 12:34 PM Reply With Quote
Those grinders are great. i used one with a diamond blade once for cutting a clay waste pipe underground. The bugger grabbed and pulled out of my hand. Luckily it only went forwards and stopped soon after.
Had to go inside to change after that!!!!!
Confused but excited.
posted on 30/5/06 at 04:49 PM Reply With Quote
And make sure the sparks go straight down. I got carried away the first time and set fire to my jeans!
posted on 30/5/06 at 08:47 PM Reply With Quote
When I was a foundry worker one of the fettlers lost his right thumb to one. They put it back for him but he couldn't bend it after so it was more of a cosmetic procedure.
robertst
posted on 30/5/06 at 09:37 PM Reply With Quote
had my first problem. didnt really realize how far back the sparks could fly and they all hit my window and buggered it all... oops! parents were pretty mad i screwed up a double-glazing window. told them it was the dog
apart from that... pretty scary but now that i dont need to cut 3mm thick tube anymore i can change it for a good small Black and decker. the one i had before lasted exactly 8 minutes before burning out from exhaustion
Tom
posted on 30/5/06 at 09:59 PM Reply With Quote
For a 41/2" angle grinder you can't beat a cheap Chinese one for about £12 off the market. Mine outlasted a Makita and it has been absolutly beasted. I have even used it to stop a van rolling downhill.
I bought it to do one job and throw it. That was over ten years ago!
Vibrates a bit, but still going stong.
I recon it's because they don't have Fridays in China.
[Edited on 30/5/06 by Confused but excited.]
lexi
posted on 30/5/06 at 10:20 PM Reply With Quote
A necessary evil is what they are. Noisy diirty and dangerous......I have them in the 3 sizes and also a Stilhlsaw and I conbstantly think of ways to avoid using them until I say to myself.......get the bloody grinder on it!!!!
Alex
wilkingj
posted on 30/5/06 at 10:33 PM Reply With Quote
9" grinder, a great tool for those larger jobs.
I put one down whilst the blade was still spinning (power off) and it hit the ground, twisted and run across my toes.
Fortunately there were very thick leather work shoes. It still went through leaving just the sock between me and the blade.
I ALWAYS wear steel toecaps ever since.
Be Warned, Excellent tool, bloody dangerous when it all goes wrong.
Get Full face Shield (Sparks and exploding discs) Eyes and faces are very soft targets, DONT RISK Them
Steel Toecaps, (see above)
Leather gauntlets / welders gloves (Would take a finger off in a flash of the eyelid)
Even consider the 4.5" ones as a hazard.
I buy the cheapo 4.5" ones, good value for money.
I use 1mm Slotting discs in the small grinder. Gives a nice neat cut, less sparks and less waste, and less heat.
1mm discs do wear quickly, but worth the cost.
Please think Safety First.
Best Regards
Geoff
http://www.v8viento.co.uk
NS Dev
posted on 31/5/06 at 08:04 AM Reply With Quote
Alex
Yep, smelly dirty horrid things, avoid at all costs and use something accurate.
They are great for hacking up old cars and scrap iron but that's about it!!!
posted on 31/5/06 at 08:10 AM Reply With Quote
Don't know what all the fuss is about - I can mark out and hacksaw a bit of 25mm square tube in the time it takes to get the grinder out, plug it in, get the safety gear on, etc. etc.
I can also hacksaw at 11:00pm in my garage, without upsetting the neighbours.
An angry grinder is perfect for tidying up welds, etc, and it's hard to think of a better tool for that job, but it really is OTT for cutting bits of tube!
robertst
posted on 31/5/06 at 02:43 PM Reply With Quote
imo the hacksaw made about as much noise as the grinder (except the motor whirring), but when i cut some tubes with the hacksaw, that pulsating screech made me realize you make less noise, or at least a shorter durating noise with a grinder than with a hacksaw. fair enough, we're talking about 1.5mm tube which is nothing....
Tom
flak monkey
posted on 31/5/06 at 02:46 PM Reply With Quote
If it was screeching when you were cutting it with a hacksaw you need to learn how to clamp your work
Cutting straight with a hacksaw is an aquired skill and it takes practice, which many dont posess! Movement from the shoulders not anywhere else, use 2 hands, and let the blade do the work
Sera
posted on 31/5/06 at 02:50 PM Reply With Quote
I was about to say the same! If the work is held properly in the vise, and you're cutting nice and steadily close to the vise jaws, then you should make very little noise.
Same goes for filing...
robertst
posted on 31/5/06 at 02:53 PM Reply With Quote
hmm. good point.. i'll try that..
was holding the tube with my foot.. but still using two hands...
Tom
flak monkey
posted on 31/5/06 at 02:55 PM Reply With Quote
I wouldnt let you near a grinder
If you dont have the right tools for a job, dont try it. IMO of course.
[Edited on 31/5/06 by flak monkey]
Sera
robertst
posted on 31/5/06 at 02:57 PM Reply With Quote
no... for the grinder i use two vices and three clamps... i'm not that reckless!!!
just didnt have the intelligence to use them with a hacksaw
Tom
Aboardman
posted on 31/5/06 at 05:15 PM Reply With Quote
what is wrong with holding material in one hand and grinder in other hand, done loads of times,
posted on 1/6/06 at 07:19 PM Reply With Quote
Get one of these! £18 off ebay, takes Stihl saw blades. Safe as house. Then just a small 4" grinder is needed for the small jobs. By the way, I hacked my donor about with a 350 petrol Sthil.....
[Edited on 1/6/06 by coozer] Rescued attachment P8290001.JPG
wildchild
posted on 2/6/06 at 09:28 AM Reply With Quote
Originally posted by coozer
Safe as house.
I'd agree if it was sat on a bench rather than a wheelie bin!
http://www.wildchild.org.uk
Build photos on Flickr
James
posted on 2/6/06 at 11:28 AM Reply With Quote
Errr, cos you can slip (like I did once) and catch your hand with the grinder (like I did once).
And I can assure you The Tool is as effective at removing the skin from the back of your hand as it is at taking off paint/rust!
It's since then I've insisted on gauntlets whenever grinding!
Or maybe you were joking... sorry!
James
<<  1    2  >>
