Author: Subject: Stair Spindle Spacing......
Surrey Dave
posted on 31/5/06 at 08:13 AM Reply With Quote
I'm replacing my 60's stair panelling with spindles, is there an EEC directive on spacing?????
I'm thinking 4" gap between ,what are your's????
posted on 31/5/06 at 08:21 AM Reply With Quote
There is a legal requirement (UK, not EU!) - 4" does sound right. It's meant to be narrow enough to stop kids jamming their heads in the gap...
Danozeman
posted on 31/5/06 at 08:45 AM Reply With Quote
10mm gap so a childs head cannot get through. I changed mine last year. If you get the proper rails they have pre cut spacing fillets in.
Its not a cheap job but looks much better. I found BnQ to be the best priced place.
This might be handy
Dan
posted on 31/5/06 at 09:02 AM Reply With Quote
10mm?
Seems small to me, do you mean 100mm (roughly 4 inches)?
Surrey Dave
posted on 31/5/06 at 09:15 AM Reply With Quote
Good Link, gap must not allow a 100mm sphere to pass through, sounds like SVA for stairs!!!!!!!
Therefore gap should be 99mm or less....
Aboardman
posted on 31/5/06 at 12:17 PM Reply With Quote
stainless steel handrails with glass infills.
posted on 31/5/06 at 12:20 PM Reply With Quote
Let the little blighters get their heads jammed! let Darwinism improve the gene pool!
P.S. I am only joking, just in case someone gets uppity.
DarrenW
posted on 31/5/06 at 12:21 PM Reply With Quote
Staircase ive put in recently had pre cut spacers in the hand rail, you cant go wrong with those.
posted on 31/5/06 at 03:07 PM Reply With Quote
Just measured mine in my pre 1900 house and they measure 86mm. SVA friendly or what?
posted on 31/5/06 at 03:45 PM Reply With Quote
When we took the panels off our stairs in a house we used to live in the spindles were underneath.
Johnmor
posted on 31/5/06 at 05:41 PM Reply With Quote
100mm min at any point, (remeber to check at the turned part of the balustrade).
Hand rail min height 860mm above the nosing line of the treads, I.E put a straight across several steps and check height from this point.:
lsdweb
posted on 31/5/06 at 06:11 PM Reply With Quote
Building Regulations - Approved Document Part K - have a look here
Makes SVA look easy!
Regards
Wyn
Aboardman
posted on 31/5/06 at 10:17 PM Reply With Quote
Some good details / installation guides and spindle designs here
http://www.richardburbidge.co.uk/main.asp?page=579
and min height is 900mm not 860mm (might be in scotland they have own regulations)
zilspeed
posted on 31/5/06 at 10:58 PM Reply With Quote
yep - 100mm.
That's why the man from building control has 4 inch balls
