Author: Subject: Velocity clutch cable
Stewart Kimber
posted on 31/5/06 at 09:05 PM Reply With Quote
Silly question but can anyone advise on type of spring for clutch cable to pedal. Build manual just says 65mm spring. Presumably that is an expansion spring.
wicket
posted on 31/5/06 at 10:01 PM Reply With Quote
Its a compression spring
jcs
posted on 8/6/06 at 09:59 PM Reply With Quote
If its any help I used a cut down throttle return spring from a sierra carb.
posted on 14/6/06 at 12:06 PM Reply With Quote
Not Luego related but
I find some handy springs in old car seats when I go scrounging in the scrapyard. What spring you need depends which side of the pivot point you put it.
