phil_far
posted on 4/6/06 at 07:42 AM |
Fire Blade Fuel line
While I was connecting the fuel line to the filter and carbs I realized that the fuel fittings on the crabs are 3/8 (9.5mm) whilst my fuel line is
5/16 (8mm). Is it ok if I use a fitting from 5/16 to 3/8? Do i have to replace the whole fuel line? (Braided and very expensive!!!)
Regards
Philip
G.Man
posted on 4/6/06 at 09:28 AM |
it will fit if you push hard enough
Opinions are like backsides..
the_fbi
posted on 4/6/06 at 10:13 AM |
I came across the same thing this week too.
I'm just going to get a fuel filter with different (the correct) size inlet and outlet.
Not found a cheap one yet though.
