Just
posted on 9/6/06 at 11:33 PM |
Ford engines - which destruct if cambelt snaps
Just wondering if there is a rule of thumb. Specifically are the 1.8 and 2.0 SOHC engines from the Sierra interference or not, I have heard the 2.0
isn't but the 1.8 is?
natehall
posted on 9/6/06 at 11:55 PM |
Those that do
CVH
DOHC
Those that may do (no experience with thesee yet)
Zetec
Duratec
Pinto 1.8
Those that dont
Pinto 2.0 (checked on a head at full lift - unless the piston goes up into the combustion chamber - not a chance)
Pinto 1.6, will work after a bust cambelt
If it aint broke, uprate it
if it is broke, uprate it
http://www.modders-uk.co.uk
Fatgadget
posted on 10/6/06 at 12:31 AM |
I have come across a 2 litre Pinto with bent valves after cam belt faliure.
flak monkey
posted on 10/6/06 at 05:57 AM |
2 litre pintos wont bend valves unless the head been skimmed a lot and the block is decked. Chances are on a very high performance engine you might
bend valves, on a std one you wont.
Most of the 16v engines will bend valves/punch holes in pistons is the belt breaks.
Sera
http://www.motosera.com
BKLOCO
posted on 10/6/06 at 06:27 AM |
The 1.8 & 2.0 Zetecs self destruct in a BIG way.
I would think the smaller ones do as well.
stevebubs
posted on 10/6/06 at 04:11 PM |
Yep - 1.6 do too
