GregMcN
posted on 11/6/06 at 09:35 PM |
R1 oil level
Please can anyone tell me where oil level should be Vs sight glass on an R1
Thamks Greg
skydivepaul
posted on 11/6/06 at 10:20 PM |
should be top of the glass plus 250ml
or
top of the glass when the engine is ticking over
http://www.smartideasuk.com
http://www.smartmapping.co.uk
HD CCTV
IP security systems
access control systems
Ferrino
posted on 14/6/06 at 11:45 AM |
Here's a question: I have seen 2 different tilt angles of the R1 mounted in BECs: either with the bottom of the sump horizontal (which I think
is more faithful to the orientation of the engine in the bike when it is stationary and as seen
here) OR with the sump gasket horizontal (as I have on my BEC).
Do you think there will be a significant difference in the oil levels indicated by the sight glass in these 2 cases? Hoping not (otherwise I guess I
would have to check the 'true' overfill level by tilting my car over)!
posted on 14/6/06 at 11:59 AM |
I've looked at them in the bike shop and they check the oil with ithe rear up on a paddock stand which puts the engine at a different angle to
standing on it's wheels and they haven't had any problems with one yet.
Ferrino
posted on 22/6/06 at 10:49 AM |
Thanks - had visions of having to tilt the car over on one side in order to achieve the 'normal' orientation
