Author: Subject: Weiging the car
tks
posted on 15/6/06 at 06:02 AM Reply With Quote
Weiging the car
how could i determine the weight of hte car with out one big scale?
if i buy 4 on on each wheel could i then determine the total weight?
Tks
zetec7
posted on 15/6/06 at 06:36 AM Reply With Quote
Yes - and you can use the individual corner weights to adjust your springs/shocks to give equal weights on all four corners, to improve handling...
Tricky Dave
posted on 15/6/06 at 08:36 AM Reply With Quote
I'd be seriously interested in knowing where you can get 4 reasonably priced scales from to do that... or maybe a group buy?
roadboy
posted on 15/6/06 at 08:54 AM Reply With Quote
We have proper corner weight scales, but if your car is light enough you can use 4 cheap bathroom scales, or if it is heavier do the front & back seperately using 2 scales with a peice of wood across them on each pair of wheels.
Hope that helps.
regds
Ian
iank
posted on 15/6/06 at 09:22 AM Reply With Quote
Depends on how much accuracy you need. Cheap bathroom (spring) scales are generally hopeless.
A public weighbridge will get within 10kg for the whole car, but is obviously no good for setting up corner weights. Don't know if they have those in Spain though.
zxrlocost
posted on 15/6/06 at 10:04 AM Reply With Quote
when you do the SVA hell weigh your car
posted on 15/6/06 at 11:20 AM Reply With Quote
You could use four scales - one under each wheel - just make sure they are all level first.
Chris, they don't actually weigh your vehicle at SVA, they just obtain your individual axle weights which, when added together does NOT equal the actual weight of your vehicle.
Phil
andyharding
posted on 15/6/06 at 12:26 PM Reply With Quote
Phil
I asked him and he told me my total weight...
procomp
posted on 15/6/06 at 01:25 PM Reply With Quote
Hi using bathroom scales for corner weighting the car is never going to be a usefull operation as they are so inacurate it is almost a joke. you could try the sort that they sell in tweeks ect that do a wheel at a time price £150 ish i think. Or get it profesionaly weighted for £30. Or just pay £150 ish and get the whole car setup profesionaly then you have all the info you need and recomondations to work on in the future and have a car that you know is right for peace of mind.
ernie
posted on 15/6/06 at 04:08 PM Reply With Quote
Yes been there done that with asda scales realy does not work out and sold them at the boot sale. If your anywhere near Brum try Procomp. brilliant
tks
posted on 16/6/06 at 09:30 AM Reply With Quote
no its not for SVA
but to make up the spansih vehicle papers!
you need to do that over here with an engineeer wich in fact just asks you and takes the meter out of the pocket to measure the car up.
Will take it to one of the Porn (dismantle uhh butcher fabrics??) well for the spanish man: "mataderos" and for the dutch boys: "slachthuizen"
their they have a weight bridge wich should be able to weigh my car (i hope).
in the garage i was. they had a hydraulic installation wich could measure weight and also tell you something about the suspension.
but when that thing started to vibrate it was almost my hole car exploding!!!
also it couldn“t measure very fine because of the low weight.
i needed to sit on the front to generate a reading.
for the rear the same.
anyway will search a way.
Tks
