New Topic New Reply
Author: Subject: how easy is it to change hub carriers?
peterriley2
posted on 15/6/06 at 08:40 PM Reply With Quote
i wanted to change the hub carriers- (i think thats what their called- the bit the alloys attaches onto) from the normal sierra ones to 5 stud ones (ive seen some nice 5 stud alloys on ebay). how hard it this to do, and would i be able to change them back if i wanted to? help would be appreciated!!!
Joel
If you dont respect yourself, dont expect respect from anyone else
Live your dreams, dont dream your life
Women only want you for one thing- everything!
natehall
posted on 15/6/06 at 09:01 PM Reply With Quote
i can only comment on the drum rears
undo hub nut
get 5 stud off granada
hammer 4 stud off
put 5 stud on
redo hub nut
fit new alloy
If it aint broke, uprate it
if it is broke, uprate it
http://www.modders-uk.co.uk
peterriley2
posted on 15/6/06 at 09:25 PM Reply With Quote
would that work for disks do you know?
Joel
natehall
posted on 15/6/06 at 10:53 PM Reply With Quote
would be similar
but im guessing instead of remove drum
remove calipers, carriers, pads discs etc
and undoing the hub nut will be fun (from memory i cant remember if the hub nut is underneath the disc
jollygreengiant
posted on 16/6/06 at 04:22 AM Reply With Quote
Originally posted by natehall
would be similar
On the rears you would find the hub nut outside facing you as you take the wheel off.
On the fronts you would find the hub nut inboard behind the dust cover.
Front and rear hub nuts are done up to about 280Nm of the top of my head.
SilverFox
posted on 17/6/06 at 02:51 AM Reply With Quote
I would be interested to know how you make out on this swap. Our Merkur XR4ti is the 4 bolt and the scorpio is the 5 bolt. I too thought they were interchangeable, so got one of each.
Turns out that they are different designs altogether. The 4-bolt has the bearings nounted on the lobro shaft part and the 5 bolt has the bearings mounted on the whell hub half. Maybe different for the Sierra family
New Topic New Reply
