Author: Subject: Rubber Thread/Nut Covers
Ferrino
posted on 23/6/06 at 09:37 AM Reply With Quote
Does anyone know where I can buy those black rubber 'condoms' that slip over the end of exposed threads to prevent corrosion and sharp edges? I'm looking for a couple to go over the end of some 7/16" threaded bar. Looking for the rubber/flexible type rather than the hard nylon stuff (doesn't have to be SVA-compatible).
Thanks!
andyharding
posted on 23/6/06 at 09:54 AM Reply With Quote
What you're looking for is called rubber hose
Ferrino
posted on 23/6/06 at 10:05 AM Reply With Quote
Thanks but I am after something with a neat, closed end, as it is clearly visible on the exterior of the car.
Danozeman
posted on 23/6/06 at 10:39 AM Reply With Quote
These are rubbery from tifosi and u can heat them up a get them over larger things.
Dan
Ferrino
posted on 23/6/06 at 11:59 AM Reply With Quote
Cheers Dan - that's the ticket!
