AlexS
posted on 25/6/06 at 05:34 PM |
Clutch....again
6 hours of blood sweat and swearing later i have taken the engine out turned the clutch plate round and put it all back in
now the clutch goes down...and doesnt come back up/go back in???it goes if i push the fork back.
Any ideas? Im thinking maybe the fork has come off at its attachment on the other side of the 'box so nothing to make it return to normal, but i
hope its something really simple!
p.s. 1600 xflow on escort 4 speed box
owelly
posted on 25/6/06 at 05:49 PM |
but does it work when you press it? Does it disengage the clutch? If it has come off its clippy thing, it won't move the CRB.
http://www.ppcmag.co.uk
AlexS
posted on 25/6/06 at 05:52 PM |
I dunno, thing is i dont want to continue putting the engine back together only to find i have to take it out again so once id secured engine to
bellhousing and got rid of the engine crane i tried it
Is only way to find out finish reconnecting everythign then try it?
gary gsx
I would imagine if the clutch fork had come of its pivot point it would be sloppy and there would be no resistance as it wont be pushing clutch
properly,
Does the centre plate slide up and down on the input shaft sounds like its stuck on there, maybe a bur on the splines
Just a thought
Gary
AlexS
posted on 25/6/06 at 05:56 PM |
bur on the spines?
When i had it out i checked and everything was oving smoothly, there is no resistance on the clutch it just slides down to the bottom and stays
there
sounds like i may be unfortuantely right and the fork has left its pivot
AlexS
posted on 25/6/06 at 08:44 PM |
grr cant for the life of me seperate the gearbox from the engine by more than about 2cm so calling it a night, why does everything go wrong in the
good weather?!
Dusty
posted on 25/6/06 at 10:47 PM |
With a torch and a crawl under the car you can see quite a lot inside a type nine bellhousing. May be able to get a direct visual check.
AlexS
posted on 26/6/06 at 03:54 PM |
Hmm ill try that i tried to reach inside but i couldnt get my hand in properly, to be honest it doesnt matter if its stuck or off the pivot ill have
to take the engine back out to look, although the engine has decided it likes the gearbox and the two refuse to come more than an inch apart!
any hints on that?never had a problem before! yes all unscewed and yes gearbox supported and engine on crane
posted on 26/6/06 at 05:57 PM |
Can you get to the clutch securing bolts maybe through the clutch lever hole in the bellhousing? might be worth undoing them if all else fails at
least that should help get the engine out
owelly
posted on 26/6/06 at 07:05 PM |
Try taking the s/plugs out and turning the engine over as you wiggle!! The two things may be related! Did you have the plate dead central?
AlexS
posted on 27/6/06 at 12:51 PM |
Yep i spent ages lining it up!
It seems to like the engine coming out at a funny angle but go in at a different one, you know just to be awkward!
Will try turning it over see if that helps
cheers
AlexS
posted on 3/7/06 at 06:08 PM |
And Im back soo i get the engine out and the clutch fork is fine...infact everything seems fine, only thing i can think of is try to reset the clutch
plate and see if it wasnt quite lined up straight...
Nipping to get more oil but meanwhile, anyone got any ideas????
Macbeast
posted on 3/7/06 at 08:55 PM |
Not sure if this is relevant, but here goes....
When I did the clutch on my Bedford Rascal I had a lot of trouble mating engine and gearbox and in getting clutch to work properly. It turned out that
the release bearing was tilting from the vertical as I pushed the gearbox onto the engine. The CRB was meeting the clutch plate springs at an angle
and was hanging up on the end of the splines.
Made sure the face of the CRB was vertical as it met the clutchplate and no further problems.
Best of luck
AlexS
posted on 4/7/06 at 08:14 AM |
Still no luck so a quick review..
Xflow engine, 4speed ford 'box
Clutch pedal goes down, pulls the fork on the gearbox forward (towards engine) but doesnt return. If i pull the pedal back up it goes but it has no
auto return. The clutch plate is the right way round ive checked and oiled all the bits on the splines. Dropped the engine in last night i lined up
the splines and checked everything twice and engine went in nice and smoothly
Still no luck, Im clean out of ideas (and not very good with clutches)
Due to move house in 2 weeks so the pressure is kind of on with this...and yes I know the idea of driving without a clutch and just stopping the
engine when i want to stop but thats a last resort
Macbeast
posted on 4/7/06 at 10:41 AM |
Clutching (sorry) at straws here...you DO have a clutch release bearing attached to the fork?
DIY Si
posted on 4/7/06 at 03:23 PM |
Shoud there be a spacer? When you push the pedal forward does it actually apply the clutch? If not, sounds like you may just need a spacer/different
release bearing.
AlexS
posted on 4/7/06 at 04:06 PM |
Yes there is a release bearing etc as far as I know clutches everything looks fine
Ive got a mechanic coming to look over it on thursday and see what he thinks (dont worry its a mate, not broken the golden rule and paid a fortune :-P
Ill let you know what he says and we can add it to the list of wierd things that you can do to a clutch to break it!
posted on 4/7/06 at 07:06 PM |
You may know this already, but ...
Does your clutch cover have straight fingers, or is there a significant bump at the end of each? The bump is a ____/-\ shape around 5mm high
(apolgies for the rotten ASCII graphics!).
The straight finger type needs a release bearing with a rounded front, but the bumped-finger type need a flat fronted one.
stevebubs
posted on 4/7/06 at 11:24 PM |
Where are you?
I have a disassembled crossflow / 4 speed box you're welcome to take a look at. Working perfectly before separation...
Macbeast
posted on 8/7/06 at 07:35 AM |
So wot did mechanic say ?
AlexS
posted on 8/7/06 at 06:08 PM |
Oh he said the drive plates on its last legs and id fitted it wrongly
Anyway he went off to get me a new one and he cant get it so im fitting old one back in tomorrow (with help this time) and will have 2 last a few
weeks till the new one arrives!
Feel rather daft now especially after 3 attempts i still didnt do it properly! Thanks guys! clutches arent that complicated but the people trying to
fit it can make it seem that way
