fully sideways
posted on 27/6/06 at 04:15 PM |
Capri Power Steering and reducing the ratio.
I am running a 2.8i power steering rack and the 3.5 lock to lock is not quick enough, I have thought about using gears at the base of the column to
reduce it to say 2.5 !!ANy other ideas please ?
Is throttle wide open ?
posted on 27/6/06 at 04:26 PM |
can you not change toa manual "quick" rack, it's got to be the simplest solution.
froggy
posted on 27/6/06 at 05:36 PM |
in what way is it not quick enough? if you are oversteering to that degree have a look at your suspension set up first perhaps its a grip problem ?
what set up is it using?
fully sideways
posted on 28/6/06 at 11:58 AM |
that was going to be the last resport , as i would have to run an Electric power steering set up..
I was wondering if any of the other P/s capri's has a quicker ratio... Maybe of a 280 or Tickford ?
cheers Andrew
fully sideways
posted on 28/6/06 at 04:06 PM |
Hi , the problem is not the oversteering , it is the effort required to keep up with the car on stage in chicanes , hair pins etc .. It is more of
a convenience thing really.....
but any ideas are welcome.
Andrew
Bob C
posted on 28/6/06 at 05:29 PM |
Someone (Rorty I think) posted a picture of a commercially available steering shaft "step up gearbox" a year ago or more - good luck with
the search facility.....
Bob
fully sideways
posted on 30/6/06 at 06:08 PM |
Cheers Bob, Someone mentioned to me that it might be worth fitting a late sierra cosworth power Pack??
Anyone know anything ?
cheers Andrew
