ditchlewis
posted on 27/6/06 at 07:39 PM |
Oooch that hurts~~@@::~@####
Ran the engine up this weekend then jumped out the car.... was only wearing shorts and now have a 3rd degree burn on my leg.. a big one
does anyone know where i can get a heat shield for the exaust can on an MK indy..
Ditch
[Edited on 27/6/06 by ditchlewis]
ReMan
posted on 27/6/06 at 07:41 PM |
I'm sure someone will tell you that if you had a proper engine, then that would be your passengers problem, not your's.
But I'm not going to.
[Edited on 27/6/06 by ReMan]
zilspeed
posted on 27/6/06 at 08:09 PM |
It's like broken wing stays - something that's going to happen to you eventually whether you like it or not.
bracey
posted on 27/6/06 at 08:42 PM |
europa spares do one and can have any name lazer cut into it ,75.00 i think
wilkingj
posted on 27/6/06 at 08:50 PM |
Inside of a washing machine drum, then bend to suit. nice bit of perforated Stainless
Or....
Just be MORE CAREFUL
Best Regards
Geoff
http://www.v8viento.co.uk
Deckman001
posted on 27/6/06 at 08:58 PM |
I did something similar as well, having worked on the car with exhaust fitted for about 6 months , when I did manage to get it running I turned it off
and leant over the engine to check something, forgetting I couldn't lean on the manifold with my hand from now on !! Ouch, that hurt, it took
lots of water to stop it smarting I can tell ya
I remember each time now though
Jason
Danozeman
posted on 27/6/06 at 09:03 PM |
That sounds familiar. Luckily mine wasnt that hot.
My exhaust is the passengers problem
Dan
graememk
posted on 27/6/06 at 09:20 PM |
fire blanket from ebay £10
posted on 27/6/06 at 09:23 PM |
All the formidable BEC'ers have the tell tale mark on their calf or chin... Course, I don't... yet!!!
[Edited on 27-6-06 by Hellfire]
Agriv8
posted on 27/6/06 at 10:12 PM |
burnt anckle between bottom of trousers top of trainers.
Leaning over running motor
mmm nice
emsfactory
posted on 27/6/06 at 10:16 PM |
Get a nice stainless bin from ikea and chop it up.
robertwa
posted on 28/6/06 at 12:13 AM |
How do you get a burn on your chin?
zetec7
posted on 28/6/06 at 04:44 AM |
Try here:
http://cgi.ebay.com/Robin-Hood-Locost-Westfield-Tiger-Kit-Car-Exhaust-Guard_W0QQitemZ290001525687QQihZ019QQcategoryZ100921QQssPageNameZWDVWQQrdZ1QQcmd
ZViewItem
ditchlewis
posted on 28/6/06 at 07:03 AM |
Ahh Not an uncommon occurance....
may thanks and that seven shield looks cool, might just get one...
limping but still smiling
Ditch
greggors84
posted on 28/6/06 at 10:33 AM |
Manged to get a Caterham one off blatchat for £10. Looks good and never gets hot enough to burn me.
Keep an eye out on there, or maybe out a wanted post.
Chris
The Magnificent 7!
tractorboy
posted on 28/6/06 at 11:55 AM |
you can still get burnt though as i have proved ! i have a nice burn on the back of my calf at the moment and i have a shield fitted. i managed to
step out of the car and put my leg against the end pipe after a blast . so even with a shield you still need to be careful. cheers scott
Danozeman
posted on 28/6/06 at 07:40 PM |
Your chin???? HTF?
Dan
ditchlewis
posted on 29/6/06 at 07:15 AM |
mmmm
i think the cheapest solution is to take more care and let the scars be a reminder.
still limping after 5 days and the burn is still stinging like hell.
suppose i should have gone to hospital.
next time i take the car out i will take some steak and have a bbq on the exhust.
ditch
posted on 29/6/06 at 07:37 AM |
Your chin???? HTF?
'Shin', perhaps?
iank
posted on 29/6/06 at 07:54 AM |
Yes, if it was 3rd degree you should have gone to A&E.
You need to be careful since if burns get infected things can get serious quickly. Probably worth going to your GP to get it dressed properly.
