robbydee
posted on 6/7/06 at 09:50 PM |
vernier make much difference?
currently hava a modded pinto fr33 etc, i do have an adjustable vernier fitted but its never been set, how much difference am i likely to see if i
get this done exact? is it easy to do?
nitram38
posted on 6/7/06 at 09:56 PM |
Standard verniers can be a few degrees out and can equal lost power.
If you fitted your own, then it should have come with a dial gauge.
I haven't done one for about 20 years, but I am sure someone will be along to tell you how to set it up.
If you have one fitted, it will be worth making sure that it is correct because a badly fitted one could be worse than a standard cam wheel.
cadebytiger
posted on 6/7/06 at 10:11 PM |
The best thing to do i found was to find out how far open the inlet show be at TDC and then use a dial gauge to set it. setting a number of degrees on
the crank is very hard to get accurate esspecially if the engine is fitted!
Rupert
mark chandler
posted on 6/7/06 at 10:38 PM |
Definately worth doing.
For fast road use you set the cam between 5 - 7 degrees advanced (recommended unles you sit at 6000rpm all day), this should give up more mid range.
For max power at high rev's set it up at TDC.
All you need is a dial gauge and a vernier timing wheel (or a bit of card and devide it into degrees).
The cam when set to TDC means that both valves open the same amount when the engine is at TDC, ie the inlet is partially open while the exhaust is
partially shut, advanced is the inlet open a little bit more, obvious really.
It not really practical to measure valve lift due to the opening an closing flanks on the cam so attach the the timing disc to the crank, find TDC and
zero it.
You then measure the cam lift for a pair of lobes pick a point halve way open, note the degrees and roll the enngine until the valve its halfway shut,
halve the distance and you have the valve at peak opening.
Do this for both inlet and exhaust and on your timing disc you should have three points, TDC, max inlet lift and max exhaust lift.
The best way to set the cam timing is now to revolve the engine until you both valves are equally open (devide the distance between the cam lobes
centres), then release the vernier and turn the crank until its either TDC or a 5-7 degrees advanced (depends where you want max torque/power) then
lock the vernier. Job done.
Ignore markings on the vernier, your marks on the card should be 100% accurate, the vernier may not be !
I hope that makes sense, been on the wine !
Regards Mark
[Edited on 6/7/06 by mark chandler]
posted on 7/7/06 at 11:25 AM |
I've got a file that can be printed off to do this, .pdf I think. If you need one, I will look for it, may not be able to find it though so no
promises.... ![](/images//smilies/tongue.gif)
andyharding
posted on 7/7/06 at 11:30 AM |
The correct way to setup your cam is to put a dial gauge on the #1 inlet valve and find the point exactly 1/2 way between the start and end of
maxiumum lift. Once this has been found loosen the vernier off and adjust the crank (use a degree wheel) to the figure given by the cam
manufacturer.
P.S. check your crank pulley TDC mark is actually at TDC.
[Edited on 7/7/06 by andyharding]
