Author: Subject: Pinto cam timing
westf27
posted on 7/7/06 at 06:47 PM Reply With Quote
Pinto cam timing
Having passed sva and now driving about,im doing the bits and pieces to finish off/improve etc.want to recheck the cam.What is the best way to set cam given the valve open/shut...tdcl...full lift figures seem to be hypothetical ie you never get them all right together.Please feel free to rip that apart.
mark chandler
posted on 7/7/06 at 11:52 PM Reply With Quote
5 - 7 degrees advanced, you measure the valves half way open, halfway closed and devide to find the mid point.
Rgds Mark
[Edited on 7/7/06 by mark chandler]
fully sideways
posted on 13/7/06 at 05:55 PM Reply With Quote
Robocop,
the crank pulley should just come off with a bit of persuiation (unless it has been lock tighed on).a combination of pulled and knocking stick is the next action..
If you are going to the effort of using a DTI to set the advance figures on the cam then i would find TDC with the DTI and split the degree of crank rotation whilst hte piston is at TDC at the point where in the movment is only rotational in the crank and the Piston remains static.
Alternativly you can set the cam timing by lift measurement and not duration as the it is difficult to ensure the base circle of the lobe is correct .
Hope this helps..
Andrew
Is throttle wide open ?
jollygreengiant
posted on 14/7/06 at 04:31 PM Reply With Quote
Originally posted by robocog
Q:Is there a locost way of removing the crank and cam pulleys without a puller - or will they come off easily enough without?
A:bought a puller as no ammount of levering, tapping and WD40 soakings worked on the crank - the cam pulley almost fell off when I took the bolt out
[Edited on 8/7/06 by robocog]
Normally aspirated pintos the pulley is tight but will normally fall ofwith minor persuasion.
Injected pinto's for what ever reason are always dead tight and normally need a puller.
fully sideways
posted on 15/7/06 at 02:37 PM Reply With Quote
the later injction pinto's have a diffrent front pulley as they has a pick up on them..
fully sideways
posted on 12/7/07 at 12:03 PM Reply With Quote
Yes i agree, especially if you have a non standard cam as the majority of aftermarket high lift cams are re-profiled strandards and not ground from a blank, so if you are look for a real true lift figure then you should use a DTI and set you cam timing to lift figure and not a duration figure.
hope that helps.. Andrew
