darrenga
posted on 9/7/06 at 02:52 PM |
brake balance
which brake balance is the best to use,sierra which has to be at 75 degrees or a fiat uno one that is adjustable.
JAG
posted on 9/7/06 at 05:27 PM |
The Sierrra 'G-valve' is not suitable and will not work properly on a Locost.
Which braking components do you have on the front and rear axle? It may be that you don't need a valve.
I have Girling M16 front calipers and MkII Escort 8" drums on the back axle and my car manages very well without a valve.
Justin
darrenga
posted on 9/7/06 at 05:47 PM |
sierra front and rear discs,and master cylinder
Kev99
posted on 9/7/06 at 06:37 PM |
Hi
As u are running rear discs u will need one I used the uno one like most ![](/images//smilies/wink.gif)
auzziejim
posted on 9/7/06 at 07:07 PM |
i am led to believe that a valve as fitted to mondeos and 90's fiestas are as good as anything so have opted for one of these
after sva i will fit an adjustable bias valve for when on track
