Author: Subject: Trigger wheel mounting
IainB
Builder
Posts 236
Registered 17/11/05
Location Glasgow
Member Is Offline
Photo Archive Go!
Building: Fiat X1/9 - GRP widebody, Bike carbs, Megajolt
posted on 11/7/06 at 12:16 PM Reply With Quote
I know most people remove crank pully nut and or pully to mount trigger wheel but i have a tapered pully which means this is not possible (the nut sits about 10mm inward from the outer face of the pully).
I just had my trigger wheel milled out so it slides onto a small circular ridge on the pully but now I come to how to secure it.
The pully is cast and the wheel is mild steel. is welding a good idea or could this cause cracking? not too keen to drill and tap to bolt it on for the same reason..
Any input would be great,
cheers, Iain
http://s43.photobucket.com/albums/e365/IainB1986/
posted on 11/7/06 at 01:36 PM Reply With Quote
Not done it so who know if it will owrk but what about glueing it and a small roll pin to keep it from rotating (I guess you would use 2 at oppsoite ends for balance)
stevebubs
posted on 11/7/06 at 07:10 PM Reply With Quote
Welding probably isn't too good an idea but brazing should be fine.
fully sideways
posted on 13/7/06 at 05:38 PM Reply With Quote
Hi Ian,
My first thought was i would of had an interference fit and pressed it on but yours slides on ..
you can either Braze it together or use "dis-similar" welding rods to combat the heat dispersal and diffrent cooling properties ..
Hope this helps
Andrew.
Is throttle wide open ?
posted on 14/7/06 at 07:11 AM Reply With Quote
I often wonder why people don't machin the notches in the crank pulley itself (the missing tooth may cause balancing issues but shouldn;t be that hard to rectify).
