Author: Subject: Pinto cam or head change
jamesbond007ltk
posted on 11/7/06 at 04:58 PM Reply With Quote
My car is currently powered by a 1600 pinto with twin 40's. I want more power but am going to have to stick with 1600 to prevent the insurance companies creeping up behind me, pulling down my trousers and....
Anyway, i have read that putting a cam from a 2.0 into the existing 1.6 head will make some difference due to the cam profiles.
However, seeing as my head is not suited for unleaded petrol i am considering swapping the head for a 2.0. The question i have is, will a 2.0 head fit on my 1600 block? Is it worth doing?
Rich
mookaloid
posted on 11/7/06 at 05:45 PM Reply With Quote
I would invest in a fast road cam from kent cams or piper, then do a bit of DIY porting on your current head,
The cams come up on ebay fairly often for not much money.
Mark
roadboy
posted on 11/7/06 at 06:24 PM Reply With Quote
I'm fairly sure the 2.0 head will have a larger combustion chamber hence lowering the CR & reducing performance
Regds
Ian
Jude Performance Services
andyharding
posted on 11/7/06 at 06:41 PM Reply With Quote
Changing for the 2L head will lower the CR and you will lose power.
A Piper 285 cam will give you a reasonable gain. I would couple this with porting, polishing and skimming to take the CR up to 10.5:1 on the head you have. Don't worry about the unleaded Pinto heads are rock hard.
andyharding
posted on 11/7/06 at 06:59 PM Reply With Quote
The "how to make my Pinto go faster" question comes up a lot. Mark: do you fancy putting an article on carbuilders.info about Pinto tuning?
mookaloid
posted on 11/7/06 at 10:18 PM Reply With Quote
I could do a bit but it would mainly be references to other peoples work who know a lot more about it than me
Mark
TangoMan
posted on 12/7/06 at 09:36 PM Reply With Quote
The 2.0 has a better cam and larger valves, but also larger chambers so no good for the 1.6.
Is it possible to use 2.0 valves in a 1.6 head as this would give a good improvement if coupled with a 2.0 or performance cam.
fully sideways
posted on 13/7/06 at 05:29 PM Reply With Quote
Hi, yes it is possible to use 2.0 valves in a 1.6 head, they will just need the valve seats cutting ..
match with a 2.0 or aftermarket cam and i bit more compression you should be ok..
or if you are crafty you can build a 2.0 into a 1.6 block ...!
What Carb are you using ?
Vernier cam ?
Hope this helps
Andrew
Is throttle wide open ?
