irvined
posted on 13/7/06 at 01:01 PM |
Brakes Sticking
Hello,
I had some wonky old calipers on, and it was evident they had seen better days, so I bought some reconditioned M16 calipers from rally design.
Sadly i had a bit of a problem on route to SVA. I was driving along minding my own business as you do, and then it started getting slower, and
slower, down to the point where i was in first gear and the front brakes where smoking as I tried to find somewhere off the main road to stop.
Upon stopping the brakes where locked on. At first I thought the pedal had stuck, so i checked that, plenty of wiggle, car still not moving
freely.
Prior to this, the brakes where working perfectly, both wheels had equal effort, and releasing the pedal released the wheels.
After about ten minutes i started wiggling the car back and forward, and then as if by magic, the brakes are no longer locked on. The front left
appears to be more locked thean the front right, as it was hotter, and it was pulling slightly to the left.
Before and after the problem, the brakes function normally.
When i noticed the problem, it appeared as if the brakes where getting more stuck, wheras i had expected them to fade out eventually and become easier
to drive. I don't recall pressing the brake pedal at all, let alone hard enough to cause that much braking force.
Any ideas? I'm at my tethers end
http://irvined.blogspot.com
JAG
posted on 13/7/06 at 01:06 PM |
What type of braking m/cyl' do you use?
Two cylinders and a balance-bar or one tandem cyl'?
With or without a servo/booster?
Justin
irvined
posted on 13/7/06 at 01:22 PM |
Two cylinders .75 and .6something, Luego bias bar without servo.
I should add, the previous SVA run used the old calipers, and did not give me this problem. (The effort was out by about 20% though.)
[Edited on 13/7/06 by irvined]
John Bonnett
posted on 13/7/06 at 01:30 PM |
If both calipers were afffected it is unlikely to be a caliper problem. Could it be that the master cylinder piston is not returning fully every time
and the hydraulic pressure not releasing. Perhaps it is a question of adjusting the pushrod in the balance bar.
John
fesycresy
posted on 13/7/06 at 01:38 PM |
Does the caliper line centrally with the disc ?
Check by removing the pads, bolt up the caliper and bolt up the disc.
If they are not central and the one pad is clamped then the expanded disc will cause binding.
keith2lp
posted on 13/7/06 at 02:07 PM |
Brakes
I had a the same problem with mine. Check the bias bar is letting the m/c fully return as mine was not and every time you used the brakes the pressure
built up until the brkes were on.
To rectify the problem I increased the gap between the pedal and the bias bar fitting.
Keith
muzchap
posted on 13/7/06 at 02:23 PM |
Or - take the MasterCylinder apart and make the hole in the washer bigger - it's this the bar 'fouls' on apparently.
Gent from yukspeed pointed this out to me - so I've ordered a new MasterCylinder and going to give it a go
If you believe you're not crazy, whilst everybody is telling you, you are - then they are definitely wrong!
John Bonnett
posted on 13/7/06 at 03:31 PM |
If you look in the Rally Design catalogue, they show the pushrods should be parallel with each other. The bias being obtained by screwing each pushrod
in more or less into the balance bar. If you use a dashboard adjuster, then the balance bar moves the pushrods at an angle to each other by screwing
or unscrewing and I can see that if this happens at some point there will be an issue with the washer inside the master cylinder. If both pushrods are
parallel then I think it points to the pressure not being relased becuause the front pushrod cannot retract sufficiently.
John
fully sideways
posted on 13/7/06 at 06:50 PM |
I agree with John, but just check that the front cylinder is not seized as one did it to me whilst driving in anger ! got better in the pits then
Andrew
Is throttle wide open ?
posted on 13/7/06 at 07:36 PM |
Yes the lads have spotted it defo a master cylinder pushrod problem -- as already stated usually the mushroom end of one or both of the mastercylinder
pushrods is fowling on the washer in the end of the cylinder -- really critical even loss 0.5 mm of movement can cause the hydraulic lock you
describe.
zetec7
posted on 13/7/06 at 08:54 PM |
Are the new calipers opposed-piston type, or "sliders" (where the caliper centres itself about the rotor by sliding back & forth on
pins)? If they're sliders, you're likely to find that the slider pins are corroded/dry/over-greased, any of which will cause the slider
to push over to one side. Thus, one of the brake puck pushes constantly on one side of the rotor, the rotor gets hot & expands, causing even more
pressure, causing more heat, etc. This happened to me on a motorcycle at speedfinally it seized (front wheel, of course), instant lockup/crash.
In my case, it was over-vigilance - I put too much brake grease on the end of the pin (which went in a closed hole), caused an airlock, etc....
fully sideways
posted on 15/7/06 at 02:39 PM |
if you have a pin or slider problem it will be identified imediately in the travel and exerted pressure needed to apply a brakign force ..
definatley sounds like a master cylinder problem
MikeR
posted on 16/7/06 at 11:12 AM |
The new calipers should be the M16 cortina ones - twin cylinder not the slider ones.
irvined
posted on 16/7/06 at 05:43 PM |
Well, it definitely looks like a master cyl problem, it worked before i changed the calipers though, but as its been sitting for two months pretty
exposed to the elements, i wouldnt be surprised if something in the master cyl got a bit sticky.
I'll whip it out and have a look next time i'm over. Contemplating hiring an other luton van and taking itin the back of that for the
SVA, I know it will pass SVA, or at least i'm 99.99% confident this time around, at least after i can drive it, i'll be able to give it a
proper drive to find out whats wrong. Talk about chicken and egg.
Cheers guys.
MikeR
posted on 16/7/06 at 11:28 PM |
you could always drop it off at mine
i'd fix it and get it through SVA then "look after" it for a while
aka the rest of the summer.
irvined
posted on 17/7/06 at 11:49 AM |
Ahah,
Sounds like a plan, tell you what, you go up north, fix the brakes for me, and i'll drive it down to yours via Carlisle SVA, then you can look
after it for the afternoon whilst I register it
MikeR
posted on 17/7/06 at 05:37 PM |
hmmm, i'm spotting a flaw in the plan here......
involves me doing all the work and getting none of the benefits.
oh, just realised, i'm busy :p
