Author: Subject: Fuel Breahter
richwalker
posted on 15/7/06 at 03:58 PM Reply With Quote
Fuel Breahter
Am I right in thinking that I need a fuel breather in the fuel system somewhere. The cap doesnt have a breather built in. Its a ford injection fuel rail onto a 1800 zetec. Thanks.
RazMan
posted on 15/7/06 at 05:16 PM Reply With Quote
Quite a few recent threads on this subject ...... the search facility works too
Try here for a start
Raz
richwalker
posted on 15/7/06 at 05:29 PM Reply With Quote
Hmmm yes the search facility does work, I found that out when I originally searched for the topic, however when I didnt find anything I thought I would ask. I will make my question a bit more specific. The topic you have pointed out relates to a tank with a breather. My tank does not have any more outlets, one for the outlet and one for the fuel return. Do I need to make another hole in the tank or somewhere else perhaps?
BKLOCO
posted on 15/7/06 at 05:39 PM Reply With Quote
Yes
richwalker
posted on 15/7/06 at 05:48 PM Reply With Quote
Thanks. Worth checking before making more work.
RazMan
posted on 15/7/06 at 08:48 PM Reply With Quote
My reply may have appeared to be sarcastic - sorry if I made that impression
You will definitely need a breather of some sort or your tank will slowly implode (I've see this happen )
If you can drill a hole in the highest point and insert an empty tyre valve or something similar and connect a valve of the type discussed in the linked thread, you should be fine.
Raz
richwalker
posted on 16/7/06 at 06:52 AM Reply With Quote
Tank imploding, sounds interesting. Good idea though better do something soon.
