richwalker
posted on 16/7/06 at 09:36 PM |
Cam Cover Breather
Appologies if this exists, ive used the search but didnt find the answer I needed. Where do I need to connect the breahter on the zetec cam cover too,
if anywhere? Thanks.
RazMan
posted on 16/7/06 at 10:28 PM |
It can go to the intake but a catch tank would be my choice.
Raz
BKLOCO
posted on 17/7/06 at 05:10 AM |
A catch tank seems what most people do.
However. I have a 75,000 mile silver top Zetec that I have now done over 2000 miles in with the breathers routed to a catch tank. So far (even with
some pretty agressive driving) I have got zip in the catch tank.
From this I would guess that you could probably get away with just a little breather filter. As long as your Zetec is in reasonable health.
roadboy
posted on 17/7/06 at 07:59 AM |
Make up a cheap catchtank, if you just use a filter & you have blowby it will spray oil all over the enginebay with a fire risk.
HTH
Ian
Jude Performance Services
richwalker
posted on 17/7/06 at 08:22 AM |
Thanks, catch tank seems to be the way forward then.
