Author: Subject: Welding Spring Steel??
RPS
posted on 19/7/06 at 07:22 AM Reply With Quote
Does anyone know if/how you can weld spring teel. I have a leaf spring broken on my off-road buggy and in my experience, once welded, spring steel breaks again quite quickly right next to the repair.
Any help will be appreciated.
Thanks.
RPS
JAG
posted on 19/7/06 at 07:34 AM Reply With Quote
It'll happen exactly as you say.
Welding spring steel will remove the springyness.
Being more technical; the heat required to weld the steel will locally anneal it hence reducing any 'strain recovery' behaviour and f@*king it up good and proper.
Buy a new one unless you have the facilities to weld and then re-heat treat. Although it would probably still break right next to the weld even then.
Justin
posted on 19/7/06 at 07:39 AM Reply With Quote
Any welding will muck up the steel's temper - and even if you heat-treat it, the weld is unlikely to be carbon steel so won't take tempering.
Most spring repair shops just replace the broken piece - take some stock material of the right width & thickness, cut it to length and shape it, then re-temper.
It's worth asking the cost, as it may be cheaper than you think.
The alternative is to find another spring that you can canibalise for a new leaf.
