bernard
posted on 21/7/06 at 05:28 AM |
zetec mapping
hi, can anyone in this laptop help me because i am running out of ideas. I have i nstalled a zetec 1800 , running bike carbs and mega jolt .
electronic ignition in my robin hood 2b plus. I have a missfire at 4000 revs in top gear despite trying every possible map i can find i still have
this problem. last week bogg brothers set up the carbs for me but its still missfiring at 4000. any ideas or help would be very gratefully received,
Bernie
[Edited on 21/7/06 by bernard]
rayward
posted on 21/7/06 at 08:08 AM |
and welcome.
have you used screened cable for the connection bewteen the VR sensor and the EDIS unit??.
if so, is the screen only connected to ground at ONE end??.
Ray
paulf
posted on 21/7/06 at 08:22 AM |
Also check that the earthing point is a common connection for all the shields at the Edis unit, I connected the VR, pip and saw cable sheilds together
and earthed them on a tag on the Edis mounting bolt.
Also would be worth trying another coilpack and checking the rev limiter is not set to low.
Paul.
quote: Originally posted by rayward
and welcome.
Ray
Surrey Dave
posted on 21/7/06 at 08:48 AM |
How did Bogg Bros set the carbs if it misfires at 4000rpm , does it clear and reach full revs OK , did it misfire on the rolling road?
TangoMan
posted on 21/7/06 at 11:44 AM |
Bernie
If they set up the carbs, how come it is still missing. Was this done static or on a rolling road. If it was done static with no load them it would
suggest your problem to be electrical. Either earthing of screened cable as suggested or possibly just a lead breaking down.
How far is your sensor from your toothed wheel.
I would suggest getting it on a rolling road as you can then analyse what is happneing when it satrts to miss. Could be one cylinder, could be them
all. At least you will see what is happening with the spark so can exclude it.
Summer's here!!!!
bernard
posted on 21/7/06 at 04:27 PM |
hi, in answer to a few of your questions it only missfires in top gear at 4000 revs . When it was on the rolling road he did not have it in top gear
,it was fine in the others.When i took it out on the road to try it i coulnt find a road long enough ,it was missing ever so slightly . I told the old
guy at bogg brothers who suggested new champion plugs would cure it so i got those but still no better.It probably wasnt a proper rolling road he was
just tuning the carbs because it was running a bit weak.As for the screening of the vr senser i didnt know it had to be earthed at both ends. Help !
bernie
posted on 21/7/06 at 04:51 PM |
Are you using the standard Ford HT leads ? have known them to break down and cause problems . From experience I would not use Champion plugs , would
recommend NGK . You may find if it is the leads you might have problems with the plugs even though they are new . Also try parking somewhere dark and
lifting bonnet, check HT leads/coil for small sparks tracking out . BUT DON'T try this in a garage !
MkIndy7
posted on 21/7/06 at 05:03 PM |
Every map you can find?
That could be one of your problems
Unless your very accurate at setting the disk and sencor you could be out on your TDC... hence your map might not be correct for everybody elses.
Might be worth advancing and retarding a good map by 5 deg over the whole table to see if it helps. I.e what was 10 deg becomes 5 deg etc.
Is is running a MAP or TPS System? maybe it could be a weird value on either.
Have you watched the runtime display when it hits the problematic situation?
paulf
posted on 21/7/06 at 05:27 PM |
It should NOT be earthed at both ends , only the edis end.
Paul
quote: [iAs for the screening of the vr senser i didnt know it had to be earthed at both ends. Help ! bernie
Surrey Dave
posted on 21/7/06 at 05:51 PM |
It could still be a bit weak then , if it couldn't be measured in top gear on the rollers.
When mine was a little weak it was undrivable on the motorway in top ( full load).
What size carbs ,what size main jet did you end up with?
They look like R1 carbs in your achive , most people seem to be jetted around 170 - 190.
[Edited on 21/7/06 by Surrey Dave]
bernard
posted on 21/7/06 at 07:25 PM |
hi, yes they are R1 carbs , I just had a look and the jets are 140s,
Surrey Dave
posted on 21/7/06 at 09:22 PM |
If they are 140's that sounds small , my carbs are 38mm and i'm jetted at 160 , you will have to check whether they really are 140 or if
Bogg Bros drilled them larger ,which is quite likely , you'll need some micro drills to put in the hole.
Or ask Bogg Bros i'm sure they would remember , they do lots of R1 carbs I believe
bernard
posted on 23/7/06 at 07:58 PM |
thanks for all the feedback ,I have started a process of elimination ,relaced plugs, new coil pack on , checked the wires from the throttle sensor,I
am going to put some new leads on working my way back to the EDIS then the megajolt. Keep everybody informed if i ever find out what i did wrong
,cheers
posted on 24/7/06 at 09:47 AM |
Possibly a fuel starvation problem. What fuel pump are you using?
bernard
posted on 4/8/06 at 05:09 PM |
I am running a fireblade pump which Bogg Bros said would be fine .I did a flow test on the pump and it is fine.I managed to get a disk from Emerald
so I am going to try to sort a map out .I will keep trying thanks.
bernard
posted on 9/8/06 at 08:33 PM |
Hi all, I would like to thank paulf for his help ,he made the megajolt for me and was kind enough to come all the way from kettering to help
with the missfire, it turned out to be a problem with the advance on full throttle ,I would recommend him if any one wants a megajolt building . He
is on the locost site if anyone wants to get in touch with him , I couldnt have sorted it out without his help , thanks for everyones help and advice
paulf
posted on 9/8/06 at 08:44 PM |
Hi Bernie
Glad we got it sorted and your happy with it, i was very impressed with the performance it was fun going flat out whilst Mapping it , the bike carbs
seem to work well in conjunction with the megajolt I really need to get the zetec in mine but may have problems with the height of it.
Bernie Just thought you may like to check the rev limiter set point, on my copy of the map I started with the limit is set to 6000 rpm, I know it was
reving to 7000 but the soft limit may be coming in so would check its set to 7000 or more.
Paul.
[Edited on 9/8/06 by paulf]
bernard
posted on 9/8/06 at 09:00 PM |
If you need any help paul dont be afraid ring me ,I know a bloke who does ally welding .Its a shame you cant lay it flat like we put it in the back of
your car !
