ian furness
posted on 21/7/06 at 10:02 PM |
hydrolic clutch
as anyone tride to fit an hidrolic clutch to a type 9 gearbox
DIY Si
posted on 21/7/06 at 10:04 PM |
I haven't but it is done on a regular-ish basis. What do you need to know about it? Or just if it can be done?
ian furness
posted on 21/7/06 at 10:12 PM |
what bracketing do i need, mounting points,slave cylinder and more.
DIY Si
posted on 21/7/06 at 10:18 PM |
If you want to buy a kit, talk to Burton Power. They sell all the bits needed. Or talk to Krismc on here. He's just gone through the fun of
doing this.
MikeR
posted on 22/7/06 at 08:34 AM |
so has NS Dev.
Basically you modify the bit in the middle of the gearbox where the input shaft goes. You put a Saab clutch release mechanism (which is your hydralic
slave). Drill a hole in the bell housing and feed the pipes in there.
Burton do a kit which makes it easy.
ruudbeckers
posted on 22/7/06 at 09:03 AM |
This has been discussed a few times before.
Have a look at:
http://www.locostbuilders.co.uk/viewthread.php?tid=44490
or
http://www.locostbuilders.co.uk/viewthread.php?tid=34089
Krismc
posted on 22/7/06 at 11:50 AM |
ive done it and its pretty easy!
Burton do the kit, but dont by the mount kit and the holding kits- they are just bolts and washers!
You need a APC 5 nose and cylinder and a type 9 mount from burton
.....and a bleed kit(any will do) the burton one is expensive
