ned
posted on 24/7/06 at 07:28 AM |
oem duratec turbo's?
Just wondered if anyone could confirm this but the last couple of weeks some of the normal cars they've tested (quick saloons last week and hot
mpvs this) have had me wondering about sharing the engines.
The ford cmax last night had a 220bhp turbo engine, think they said it was 2.3 (or was it 2.5)ltr and the previous week i'm sure the 250bhp odd
mazda 6 mps thing was 2.3 turbo.
Got me wondering as to whether these are duratecs or variants seeing as mazda/ford share components as ford owns % of mazda etc etc
Ned.
beware, I've got yellow skin
James
posted on 24/7/06 at 07:33 AM |
Yeah, there's a turbo'd Duratec Mazda out now AFAIK. Read about it last week IIRC.
James
- Muhammad Ali
RazMan
posted on 24/7/06 at 07:56 AM |
This link might be of interest
Raz
posted on 24/7/06 at 08:52 AM |
Due to the enourmous amount of money spent on design and manufacture nowadays it makes economical sense to component share.
Mazda, Volvo, Jaguar, Ford, Aston Martin all have a common component pool from which to draw. Bit similar to the VAG and PSA only larger...
r3nuf
posted on 24/7/06 at 09:04 AM |
I thought that the engine in that S-max is the same one as the Focus ST. Which i believe is the Volvo 5 cylinder turbo (T5)
But i may be wrong
Gary
[Edited on 24/7/06 by r3nuf]
Drive Fast....Brake Late....Take Chances
cossey
posted on 24/7/06 at 12:11 PM |
im fairly sure r3nuf is correct, its cheaper to use and engine thats already sorted rather than develop a new one.
uklee70
posted on 24/7/06 at 03:02 PM |
Sorry for a bit of a highjack
is the 1.6 duratec the same as the 2.0 unit?
I'm thinking for a sneaky street Ka upgrade I was wondering if its a faily straight forward engine swap
what can I say I like small cars lol
ned
posted on 24/7/06 at 04:05 PM |
the 1.6 duratec is just a relabelled 1.6 zetec se (the yamaha derived ally block one) afaik
Ned.
Krismc
posted on 24/7/06 at 07:00 PM |
quote: I thought that the engine in that S-max is the same one as the Focus ST. Which i believe is the Volvo 5 cylinder turbo (T5)
But i may be wrong
you are totally correct, they are the same engines, my mate works at volvo and ive checked out the computer and its not even rebadged its got ford
written all over it the the S-max, St and T5 share the same engine- but have different ECus
and the new volvo small car is actually a ST floor pan/chassis and some panels are the same- ive seen one and its very impressive and slightly better
looking than the ST
but as you can see its far to similar to miss- i seen it with a little less black covers on than this and i thought it was a ST at first i think its
call a c30
Ned.
thats what i thought at first after reading all the info from here, i seen a post that mentioned that before but ive got a 1.6 SE sport Focus and a
1.6 duratec street car- and the engines are not the same- they dont look it anyway and the street car is way faster, and the power bands are different
and the rev limiter are set at diff levels
[Edited on 24/7/06 by Krismc]
posted on 25/7/06 at 05:08 AM |
3 weeks ago I was in the Ford Plant in Genk. They are starting to build the new SUV and S-max Galaxies there. In the 'hall of fame' were
they show the history of the plant, (mk 1&2 escorts, cortinas, sierra's, mondeos transit etc)
they have a layout model of the trans they use on the Galaxy. It will be a common platform that will share the same underpinnings as the the new
Mondeo out next year.
It has what looked like to me a Duratec motor on the front with turbo hanging off the back. On the display next to it was a ST220 that looked quite
menacing in the polished hallway!!
UncleFista
posted on 25/7/06 at 10:19 AM |
But i may be wrong
The 5 pots used in the Ford range are not the same engines as the 5 pot in the T5.
It's similar, but smaller, it's a cheaper version of the T5 engine (still by Volvo), different castings and not as strong (less tuning
potential).
Tony Bond / UncleFista
Volvorsport
posted on 25/7/06 at 06:53 PM |
please explain your above statement , ie who told you that .
www.dbsmotorsport.co.uk
getting dirty under a bus
stevebubs
posted on 25/7/06 at 07:28 PM |
I believe the Focus 1.6 is a Zetec-E while the Ka 1.6 is a Zetec-SE / Sigma engine.
ned
posted on 26/7/06 at 01:41 AM |
puma/fiesta/focus 1.6 are the zetec se (sigma) has I helped seadog source his from some scrappers. late focus blacktop is best apparantly as focus had
tubular manifold which is easier modded to suit a kitcar than the cast job on the other engines.
Ned.
[Edited on 26/7/06 by ned]
mcerd1
posted on 28/7/06 at 12:36 PM |
The Sierras had a 1.6 Zetec that turned into the 1.8 & 2.0 Zetec E's (Focus, Mondeo)
The Duratec HE is the 1.8/ 2.0/ 2.3 replacement for the Zetec E - its basically a new engine but has more in common with old Mazda's (e.g. bell
housing pattern is Mazda not the old Ford 4cly)
1.25, 1.4, 1.6 & 1.7 Zetec's are the sigma engine or zetec S or SE (completely different - the inlet/ exhaust are on opposite sides
compaired to the Zetec E)
most old KA's are 1.3's (also old 1.1 & 1.3 fiesta's and escorts) - Endura block - based on the Valencia block - a shortened
Kent X-flow form the original 1976 fiesta (they have pushrods, not OHC's)
but I think the 1.6 in the sport KA is a newer but cheaper Brazilian SOHC 8v head version of the sigma and the latest KA's have a 1.3 version of
this engine (they call it a Duratec as well now)
btw - they also call the new V6's Duratecs
Have a look on Burton's website (tech support) : BurtonPower.com
Oh - and the s-max is the same 2.5 turbo as the Focus ST = Volvo engine (re tuned a bit)
[Edited on 28/7/06 by mcerd1]
mcerd1
posted on 28/7/06 at 12:45 PM |
quote: they have a layout model of the trans they use on the Galaxy. It will be a common platform that will share the same underpinnings as the the
new Mondeo out next year
Are you sure - the Galaxy is a VW (as is the Seat thing)
The current mondeo has a common platform with the Jag X-type, Mazda 6 and the new Landrover Freelander (just out)
Krismc
posted on 28/7/06 at 06:02 PM |
quote: I believe the Focus 1.6 is a Zetec-E while the Ka 1.6 is a Zetec-SE / Sigma engine.
well the focus has SE on the cam cover??
nope... ive got to disagree the (54plate) Ka is definatley a 1.6 16v duratec and newer design than the Zetec/sigma (SE) 1.6 in my focus(v reg)
oh and The ford Sport Ka's must have 2 different 1.6 engines- cause my engine does not look like this 1.6 one...
Do ford like to mess about or what...why cant the make it simple and stop calling the same engines dif names??
[Edited on 28/7/06 by Krismc]
Krismc
posted on 28/7/06 at 06:11 PM |
potential).
These engines are the same, ive got the print outs here from volvo and BJP services got me a ST engine layout today, (cause we might have a St engine
soon, woo hoo) and they are both the same. well they look exact!?!?! my mate at volvo still recons the only differences are the Turbos, the
manidfolds, and the Ecus!
Volvorsport
posted on 28/7/06 at 08:25 PM |
i think you are correct !!
cant see them going to all that trouble to remake the 5 cyl engine , see ford know where its at .
also ,, all the volvo tuners are offering focus ST upgrades .
UncleFista
posted on 28/7/06 at 09:23 PM |
It was stolen from an online conversation between a Ford mech and a Volvo owner in the uk.car.maintenance newsgroup.
I know, I know, never believe anything you read online, but the bloke really knows his onions and if he's wrong, then it's the first time
I know of
I'm willing (and expecting) to be corrected though of course
