big_wasa
posted on 26/7/06 at 07:49 PM |
Steering down link Without welding.....
Made my Steering down link this morning, I modified a sierra link so that it didnt need welding. and clamped it to
Can any one see any thing wrong with it ?
Gunner1
posted on 26/7/06 at 08:27 PM |
Not sure if that is the whole kit, but suggest there be a u-joint in the middle with some angle in it. In the envent of a front ender, it will save
the steering colum from being rammed into your chest.
caber
posted on 26/7/06 at 09:35 PM |
I agree that you might need to put another UJ in there to get around some of the engine bits like alternator and exhaust if they are on that side! It
looks like you have taken out a rubber link from between the two bits bolted together, putting it back may be enough to give you articulation for a
small divertion all be it with a slight loss of feel and action.
Regards
Caber
posted on 26/7/06 at 09:44 PM |
Where did you get the extra bit from??
big_wasa
posted on 26/7/06 at 10:03 PM |
It has full movment on the top and bottom uj. If I was to put in a third uj it would need mounting to the chassis like the tiger avon or it would flop
about. It clears all the running gear.
I got the Bit from a guy on here (cheers Bob ) Can be had from here www.nfauto.co.uk
Danozeman
posted on 26/7/06 at 10:25 PM |
That loosk fine to me. I had one very similar on mine until i changed it for a luego one. Im changing it back to my made one because it actualy
looks stonger...
Dan
NS Dev
posted on 26/7/06 at 10:51 PM |
looks a bit complex for what it does but fine non the less
big_wasa
posted on 26/7/06 at 11:04 PM |
Yeh was going to cut and shut but as I didnt have any materials handy I thought I would have a play
Bob C
posted on 27/7/06 at 09:21 AM |
I can't believe it's the right length!!!!
Only point I'd make is that your life depends on that bolted joint where the rubber thing has been removed - best bolts & locking nuts you
can get!!!! There's no redundancy there & it's susceptible to any inadvertent bending loads... Looks like a neat solution!
Bob
big_wasa
posted on 27/7/06 at 10:48 AM |
Yep thats how long it is, Have had it all fitted.
Sierra bits mean its adjustable by about 20mm either way.
