richyo
posted on 2/8/06 at 09:46 AM |
Weber Carb
The fuel inlet pipe on my 32/36 is loose. its so loose I can pull it out. Any advise as to how to fix it in place or is the carn goosed?
Richyo
posted on 2/8/06 at 09:56 AM |
Could you tap the hole and use a threaded fitting of some kind? Maybe a Goodridge threaded hose fitting - then make up a bit of fuel pipe with the
corresponding fitting to connect to it?
Alternatively some fuel/oil resistant instant gasket/sealer may work.
HTH
Nick
mookaloid
posted on 2/8/06 at 11:42 AM |
This used to happen a lot on Scimitars - the solution was to drill a hole in the casting and 'pin' the brass pipe in place - presumably
with some fuel resistant sealer to stop it leaking.
On my Scimitar the pipe came loose when I was touring Scotland - I was very lucky to smell the leaking petrol before the pipe came right out and
squirted petrol all over the top of the V6
Mark
NS Dev
posted on 2/8/06 at 11:49 AM |
Had just the same happen on the sierra road rally car (pinto with 38dgas carb)
Loctited it in on that
richyo
posted on 2/8/06 at 12:13 PM |
Thanks Guys
