john_p_b
posted on 5/8/06 at 02:58 PM |
nasty noise
anyone shed any light on my problems......
if i turn hard left i'm getting a really nasty crunching/grinding noise. it's not something thats just appeared it's been there
since the car was built as i put it down to a tired diff but changed that (twice now) still the same so thought driveshaft, changed them, still the
same! i was sure it was something back end but i've changed everything i can think of now, diff, shafts, hub bearings. there's nothing on
the back that appears to be catching anywhere, for the noise it makes there should be a well ground out surface by now.
i'm thinking possibly gearbox mount now? anyone know if ford still sell them?
someone give me some hope please!
built a car, built a home, had a family. lost the family, lost the home, still got the car.
DIY Si
posted on 5/8/06 at 03:02 PM |
Does i happen at all speeds? Have you checked the engine/gearbox mounts yet?
graememk
posted on 5/8/06 at 03:04 PM |
have you ran someone over ? have a check to see if there still under the car ?
john_p_b
posted on 5/8/06 at 03:07 PM |
pretty much all speeds yeah. can be doing 80 turn into a left hand hard and it'll do it and i've just pulled into my mates road which is a
left turn on a slight hill at the same time at about 5mph and it did it then.
just seems to be at the point everything twists so it's got to be something catching i guess. engine mounts are all intact and the gearbox
isn't flapping around but i just dunno if that could be the cause under load.
DIY Si
posted on 5/8/06 at 03:11 PM |
It might be worth trying an uprated 'box mount if they're available. Also, what type of engine mounts do you have? You could uprate these
for some harder rubber/polybush types?
tks
mhh
could it be a wheel arch??
problem is that in the chasis you notive everything..and mainly with your ass sow maybe thats whats creates the sentence thats from the back but maybe
it isn't....
dunno the miles you have done but i think its something small because else it would already have failed???
Tks
john_p_b
posted on 5/8/06 at 04:00 PM |
panic over
ok not that any of you where but....
found the problem and i'm blaming me dad. the bolt that goes through the centre of the gearbox mount was missing, gone, not even in site!
fitted new bolt threw it into a few bends and woohoo the only noise to be heard is the tyres smoking away
i'll start the inquest in to why it was lose enough to fall out in a few days when i get bored.
thanks for the replies though folks
DIY Si
posted on 5/8/06 at 04:25 PM |
May I suggest thread lock next time?
john_p_b
posted on 5/8/06 at 04:36 PM |
you may
i've already suggested to me dad tightening the damn thing up properly! might check it after every drive from here on in
stevec
posted on 6/8/06 at 11:27 AM |
If two people are working on a car, I reckon two people are responsible for getting it right.
Piledhigher
posted on 6/8/06 at 03:51 PM |
noise
Take a look at the fan rubbing on the radiator or shroud.
Cory
john_p_b
posted on 6/8/06 at 04:04 PM |
it definately fell in to his designated working area on the vehicle
DIY Si
posted on 6/8/06 at 04:07 PM |
Might it be worth making him check all his other "designated areas"?! Could also get him to change the oil while he's there.
john_p_b
posted on 6/8/06 at 04:12 PM |
well seeing as i've striped and rebuilt the back end twice now in search of said noise i don't think theres a lot else that can fall off!
well i hope not anyway!
DIY Si
posted on 6/8/06 at 04:17 PM |
Rubbish! There's the front end to fall apart yet!
