Author: Subject: Remote gear linkage
davrus
posted on 5/8/06 at 08:14 PM Reply With Quote
Remote gear linkage
Running a ford escort mk2 gear box , does any dody have a remote gear linkage for sale. Hope some body can help me.
Many thanks
Davrus
DavidM
posted on 6/8/06 at 01:46 PM Reply With Quote
If you can't get one you could make it. There are some pictures in my archive of how I did it.
Many others on here have also done it, each with there own variation on the theme.
Proportion is Everything
Michael
posted on 8/8/06 at 09:22 AM Reply With Quote
David.
What's is the u shaped bracket in your Gear Link Bits Picture?
Michael
DavidM
posted on 8/8/06 at 03:56 PM Reply With Quote
If you mean the one at the bottom with 2 nuts on it, that's what I made to stop it going into reverse without pressing the lever down. It locates on the underside of the lever support bracket and bolts through 2 of the 3 gear lever holes. Reverse in my locost is in the same place as 1st on all the other cars I drive.
caber
posted on 8/8/06 at 06:17 PM Reply With Quote
Here is my go at a linkage extender, a little more complex if you don't have access to a lathe, I did this in about 7 hours work.
wicket
posted on 9/8/06 at 07:13 AM Reply With Quote
I based mine on Ben Copelands design (see link), simple, easy to make and it does work very well.
http://www.locostbuilders.co.uk/viewthread.php?tid=15614
wicket
posted on 12/8/06 at 08:26 AM Reply With Quote
Pics in Gear Change Extension folder
posted on 12/8/06 at 10:34 AM Reply With Quote
Does that give a slightly "wierd" gearchange feeling as the whole lever will move back and forward rather than pivoting?
wicket
posted on 12/8/06 at 11:40 AM Reply With Quote
Not really, the gear knob moves a similar distance forward, back and side to side as the standard gear lever.
In fact the forward/back movement is shorter than the standard as the original lever in the gearbox being about half its length means that the gear knob only moves about 2" front to back.
