Cousin Cleotis
posted on 6/8/06 at 12:47 PM |
4-pot calipers unequal pistons, which way round?
should the larger piston be at the top if leading and bottom if trailing or the other way round?
Thanks, Paul
Anglia66
posted on 6/8/06 at 01:11 PM |
Fit them with the bleed nipples at the top.
gazza285
posted on 6/8/06 at 01:51 PM |
quote: Originally posted by CaLviNx
I would have the smaller piston at the leading edge with the larger piston at the bottom/rear.
Regards
Sound right to me, the smaller bore piston will move further and engage the pad on the leading edge first, preventing pad judder.
mark chandler
posted on 6/8/06 at 03:57 PM |
Small piston leading edge is the correct way.
Regards Mark
