captain carruthers
posted on 9/8/06 at 10:28 AM |
fitting twin webbers to 2ltr pinto
Guys,
Im a total newbie to kit cars and have recentlly bought a completed Indy. Im thinking of upgrading the carbs as I think the one that is on the engine
at the moment isnt performing too well. and of course i want it to sound bigger and better!!!
Question is how the hell do I go about it ?
I have seen some carbs on Ebay but not sure if they will be ok. Is it quite straight forward to fit the new carbs?
er any help would be great .
Jim![](/images//smilies/shocked.gif)
posted on 9/8/06 at 10:43 AM |
you'll need the correct inlet manifold.
depending on tune of engine, 40s may be ok, 45s more suitable, 48s
there may be some water plumbing changes needed plus possible vacuum pipe to distributor removed. oh, and the linkage for throttle and choke may need
to be changed. and different air filter.....
(it is not rocket science for sure).
cadebytiger
posted on 9/8/06 at 11:33 AM |
I think somone is selling some 40s with manifold on this website. not sure what engine they have been run with (if it is a pinto of similat tune then
you might get away with not changing the jets and such)
Remember also that if you have to disconnect the vacume advance you will need either and change of dizy or an ECU.
Rupert
mcerd1
posted on 9/8/06 at 12:18 PM |
How much do you know about your engine ??
which carb has it got at the moment ?
What cam does it have?
does it have the early block & head or the later injection type ? (injection heads flow better - injection block will have 205 cast into the side,
injection heads have 'egg' shaped inlets)
has it had any head work done?
also have you considered bike carbs ??
posted on 9/8/06 at 12:23 PM |
Just buying a set of carbs and bolting them on is unlikely to provide good results unless they came off an engine with very simmilar specifications to
yours. Carbs have to be jetted to suit the engine they are fitted to, which inevitably means a session on a rolling road to set them up.
captain carruthers
posted on 9/8/06 at 12:36 PM |
as far as i know the engine is standard. the carb on it is a twin choke webber.
I have tried tuning the current carb but can never get it to idle properly, it runs fine once you are driving but the idle is rubbish. I know the guy
who owned it last tried to get it tuned but also had no luck.
se7ensport
posted on 9/8/06 at 12:41 PM |
captain carruthers you have U2U.
captain carruthers
posted on 9/8/06 at 12:45 PM |
whats the advantage of bike carbs over car carbs. which is easier to set up?
se7ensport
posted on 9/8/06 at 12:59 PM |
Both the same to set up correctly; they will both require jetting and rolling roading.
I haven't seen any figures comparing overal performance between bike carbs and webers etc.. on the same engine, although bike carbs are supposed
to give smoother progression.
Alex
cryoman1965
posted on 9/8/06 at 01:55 PM |
Hi CC,
What you need is someone to sell you a set of GSXR 600 carbs already jetted and fitted to a stainless steel manifold. Bolts straight on to a 2.0 ltr
Pinto and runs of the pinto fuel pump.
Works great. ? ![](/images//smilies/bigsmile.gif) ![](/images//smilies/bigsmile.gif) ![](/images//smilies/bigsmile.gif) ![](/images//smilies/bigsmile.gif) ![](/images//smilies/bigsmile.gif)
Cheers Nige
andrew.carwithen
posted on 9/8/06 at 04:00 PM |
Robbie D. recently fitted a bike carb conversion (bogg bros.) to replace his twin 40 webers on his pinto.
He took me for a long drive in his Tiger Cat recently and having previously been a passenger when he had the webers fitted, I immediately noticed how
much more cleanly it accelerated throughout the rev range with no spitting back, hesitancy, etc.
He also claims to be getting much improved fuel economy as well. (Approx extra 40miles to the tankful!)
Andy.
mcerd1
posted on 9/8/06 at 04:12 PM |
Not to mention that a re-jetted and cleaned set of secondhand bike carbs with a manifold can be alot cheeper than twin webbers without the linkage or
manifold
[Edited on 9/8/06 by mcerd1]
captain carruthers
posted on 9/8/06 at 05:46 PM |
hmmm now that sounds like a better option ...cheaper and easier to install.. anyone now if there are some nokin around?
roadboy
posted on 9/8/06 at 06:33 PM |
Jetting S/H Webers could end up costing a lot of money, thats assuming they are in good condition to start with. Changing chokes & jets is costly.
The bike carb route is probably the cheapest.
Reghds
Ian
Jude Performance Services
