Author: Subject: Luego Dash
Johnny T
posted on 13/8/06 at 02:35 PM Reply With Quote
Luego Dash
Hi, just got a carbon fibre dash from Luego. Could somebody advise me on the best way of cutting the clock holes as I'm worried it might splinter if I use a normal hole cutter. Thanks John
JohnN
posted on 13/8/06 at 02:42 PM Reply With Quote
I cut mine with a hole saw, no problems, cut from face side. Bezel of instruments should cover the edge anyway
PaulBuz
posted on 13/8/06 at 02:50 PM Reply With Quote
cover it in masking tape to mark it out & drill it. remove when finished!
Paul
Johnny T
posted on 13/8/06 at 02:53 PM Reply With Quote
Thanks, I'll probably give it a go then. I was only worried because it was quite expensive and didnt want to end up having to cover it. Thanks again John
Spin8Spin
posted on 13/8/06 at 06:48 PM Reply With Quote
Hi i've just been cutting my carbon dash this afternoon, covered it in masking tape then used some decent bi metal holesaws for the gauges and a 0-30mm step drill for all the other different sized holes, worked a treat.
Matt
