Author: Subject: clipping brake lines to live axle
rayward
posted on 20/8/06 at 02:33 PM Reply With Quote
i know you can;t use tywraps to fix the xopper brake lines to the axle, but has anyone use a steel ties(like a tywrap but used to hold ally laggin onto pipes)/???
cheers
Ray
posted on 20/8/06 at 02:44 PM Reply With Quote
I welded some steel screws to the axle tube by their head, so the treaded bit stuck upwards. I then used rubber-covered P-clips and nuts/washers.
Gunner1
posted on 20/8/06 at 03:23 PM Reply With Quote
My Rover SD1 came from the factory with the steel wraps holding the pipes to the axle.
Humbug
posted on 20/8/06 at 03:27 PM Reply With Quote
I sleeved the pipes with a piece of rubber hose (fuel hose, I think), then put a honking great jubilee clip round the whole lot including the axle - 4 clips in total: 2 each side.
I am just remaking the boot at the moment, so the clips are easily accessible. No problem with them working loose so far (at 1500 miles)
The Baron
posted on 20/8/06 at 04:13 PM Reply With Quote
Jubilee clips for me too!!!
A bit over kill, but get the job done....
rayward
posted on 20/8/06 at 04:22 PM Reply With Quote
OK,
so i think i'll try the steel wraps first, at least i can change to jubilee's if i need to!!.
cheers
Ray
