gregf27
posted on 25/8/06 at 01:22 PM |
wiring horn to wash/wipe stalk?
Can someone tell me please how you wire up the horn switch to the sierra was/wipe stalk??
did a search,and it's supposed to be 53C for the horn and 54 -earth for the horn,
I rigged up a test lamp instead of cra**ing myself everytime the horn went off, and annoying the neighbours .
but the lamp stays on ,and only dims the bulb slightly when I press the washer on the stalk??
anybody else had this problem?? and how do I resolve it??
regards,
Greg
gregf27
posted on 25/8/06 at 01:40 PM |
cheers Mark![](/images//smilies/bigsmile.gif)
greggors84
posted on 25/8/06 at 02:02 PM |
Was going to do the same, but was waiting till after SVA, as the car is waiting for retest so dont want to tear it apart.
Will save a lot of hassle if you do find out the pins Mark!
Chris
The Magnificent 7!
Marcus
posted on 25/8/06 at 02:24 PM |
That's what I did, but no use to you, as I used Manta switchgear. Beginning to wish I'd used a seperate button, as mine now NEEDS
windscreen washers!
Marcus
Because kits are for girls!!
wilkingj
posted on 25/8/06 at 04:56 PM |
Regardless of what switches you have, you ought to use the switch to fire a relay, and the relay contacts to fire the horn. Horn currents are enough
to weld up the switch contacts.
relays are dirt cheap, especially if you pocket a few on each visit to the scrappy's
Best Regards
Geoff
http://www.v8viento.co.uk
kango
posted on 26/8/06 at 04:22 AM |
Does this help.
NS Dev
posted on 29/8/06 at 12:05 PM |
windscreen washers!
hehe I am using manta stuff as well, and yep using the washer button for the horn
Dusty
posted on 10/9/06 at 12:34 AM |
This might. Depends which switch you are using. Pre 87 washers is a switched earth on 53C. Use the washer switch to earth the horn relay.
87 onward 53C is a switched live feed to the washers. Use 53C to provide the switching feed to a relay.
