Author: Subject: Pinto rad cap
ady8077
posted on 26/8/06 at 04:32 PM Reply With Quote
Pinto rad cap
Hi
occasionly i get water coming out of the expansion tank overflow, i've just flushed the cooling system and put new antifreeze in, but i've notised the rad cap is only rated at 13 LBS
Acording to my haynes manual it should be 15 to 18 LBS's, the temp guage never goes above about 105, and the rad fan soon brings it down
Will changing to a higher rated cap help?
Adrian
graememk
posted on 26/8/06 at 04:50 PM Reply With Quote
isnt 105 a bit high anyway ?
ady8077
posted on 26/8/06 at 06:02 PM Reply With Quote
Is it ?
It only gets to 105 when in traffic, the rad fan comes on about 98, but because the fan temp switch is near the bottom on a vw rad the temp rises slightly before the fan brings it back down
Adrian
[Edited on 26/8/06 by ady8077]
posted on 26/8/06 at 06:14 PM Reply With Quote
Try red line water wetter
ady8077
posted on 27/8/06 at 06:31 PM Reply With Quote
Hi all
Found a 15 LBS one in halfords, will give that a go
Does anyone no how much 2 LBS's will make to the water temp?
Adrian
