ady8077
posted on 27/8/06 at 06:35 PM |
weber linkage
Hi
Fitted a new slimmer manifold yesterday, went to refit my twin 45's today and the linkage wont fit inbetween the carbs
I have fitted the throttle cable bit to the righthand side of the right carb, and made a balancing link to go between, anyone see a problem with doing
it this way?
Adrian
roadboy
posted on 27/8/06 at 06:47 PM |
I have had to cut a little bit off the link that goes into the balancing linkage to make them fit without binding on Zetec manifolds.
HTH
Ian
Jude Performance Services
lotustwincam
posted on 27/8/06 at 08:13 PM |
it this way?
Adrian
It's not recommended to do it this way as it will cause the throttle shaft to twist.
In severe cases you'll never be able to get the carbs balanced as even within the one body one of the butterfly's will be opened more than
the other.
Drew
zetec7
posted on 28/8/06 at 03:15 AM |
That's right - there has to be an adjustment available between the two carbs, or balancing them won't be possible - and you NEED to be
able to balance them!
ady8077
posted on 28/8/06 at 06:33 PM |
Hi guys
I've made a new bracket and moved the linkage back to centre
Adrian
