Author: Subject: Longer HT Coil leads for my Fireblade
phil_far
posted on 3/9/06 at 05:49 AM Reply With Quote
From where can I purchase a set of long HT coil leads for my Fierblade locost?
Still wiating for my firts drive
Regards
Philip
mark chandler
posted on 3/9/06 at 09:08 AM Reply With Quote
Make them !
Buy some 8mm copper cored HT wire from a motor factors, sold by the metre then recover the ends from you existing short leads and reuse.
The coil packs simple unscrew and pull out, retained by a rubber 'O' ring, the plug ends unscrew.
Regards Mark
andy d (rizla)
posted on 3/9/06 at 09:34 AM Reply With Quote
just buy the individual leads (carbon) from halfords or other parts store cut the ends of and just screw them on
this will give you better plug kv and much more reliability and supresion Rescued attachment P1010030.JPG
the_fbi
posted on 3/9/06 at 10:22 AM Reply With Quote
Andy: You got enough clearance under your airfilter before the ram pipes?
phil_far
posted on 3/9/06 at 03:51 PM Reply With Quote
Do you mean that I can use a normal car HT leads and replace the spark plug ends with the ones I have?
Regards
Philip
andy d (rizla)
posted on 3/9/06 at 11:15 PM Reply With Quote
exactly,they are far supirior than copper and easier to get
ps yes enough clearence
[Edited on 3/9/06 by andy d (rizla)]
phil_far
posted on 4/9/06 at 05:01 PM Reply With Quote
Thanks that sounds simple enough. Any particular car/make/model that I should look out for?
Philip
andy d (rizla)
posted on 4/9/06 at 05:40 PM Reply With Quote
they sell them single so i just meassured the distance of my longest reach and bought 4 of them
posted on 4/9/06 at 05:43 PM Reply With Quote
Don't buy 8mm lead whatever you do, you won't be able to get the ends on. At least we couldn't when we bought 8mm. Make sure you get some the same diameter as the ones you're replacing. 7mm IIRC.
Phil
andy d (rizla)
posted on 4/9/06 at 05:57 PM Reply With Quote
8mm leads fitted in pic above,piss easy to fit even after i was told by others it wont work,proof is it does
just bared back about 6mm of carbon,folded it back on itself and screwed on,job done
amalyos
posted on 4/9/06 at 08:05 PM Reply With Quote
Andy,
Nice to hear from you again,
have you got the car back
Steve.
andy d (rizla)
posted on 4/9/06 at 09:01 PM Reply With Quote
no, to busy kart racing with number 1 son,just pop in now and again to answer the odd question that i can help with
posted on 5/9/06 at 11:44 AM Reply With Quote
Some high performance leads are fully bonded and can't be separated and folded back on itself and therefore will not fit the 7mm fittings.
Phil
G.Man
posted on 5/9/06 at 02:01 PM Reply With Quote
That type you can carve a taper with a stanley knife and fit thru...
Opinions are like backsides..
posted on 5/9/06 at 05:31 PM Reply With Quote
The point I'm trying to make is that if you buy the correct diameter leads in the first place, you don't have to bodge them to make them fit.
Phil
G.Man
posted on 5/9/06 at 06:00 PM Reply With Quote
Phil
I completely understood that, but you cant always get the right diameter leads ready to hand, and the 8mm leads when forced into the caps can give a better seal post bodge...
We used them on the bikes to help with wet weather shorting...
you would be amazed how water tight they are in the coil caps... saves epoxying them in like yamaha do..
