captain carruthers
posted on 6/9/06 at 06:48 AM |
breaking under high speed
I took my Indy out the other day to test the brakes under hard breaking and got a nasty high pitched scratching type sound from the rear of the car. I
have drum breaks on the rear wheels and disks on the front.
anyone got an idea what that was?
JIm
ch1ll1
posted on 6/9/06 at 07:05 AM |
Have you jacked up the car to see?
poss back plates catching
Macbeast
posted on 6/9/06 at 07:11 AM |
Is the cat missing ?
Sorry ![](/images//smilies/tongue.gif)
Phil.J
posted on 6/9/06 at 11:01 AM |
I agree that is probably the drum rubbing on the backplate. Pull the drums off and look for a witness mark. Should be simple to 'Adjust' !
posted on 6/9/06 at 11:17 AM |
Is it only under braking?
If it's the drum catching the backplate it will be there all the time, it's probably just dust or rust inside the drum. Get some brake
cleaner or just dust the inside and the shoes and you can check for the backplate catching at the same time.
