welshboy
posted on 12/9/06 at 03:22 PM |
crossflow
hi all i need some help please iv built a book chassis and wanted to know if i could get a 5 speed box to match up with a 1300cc crossflow and if so
what could i get it out of im not sure which route to go down
mars103
posted on 12/9/06 at 03:39 PM |
hi mate,
regarding the engine to gearbox problem you have....
ford have used the same bellhousing design more or less forever therefore you can fit any ford engine to any ford gearbox
please correct me if i am wrong because you will be saving my loads of cash when i try put a cologne v6 to a mt75 gearbox
i hope this helps
Matt
rayward
posted on 12/9/06 at 04:09 PM |
a 5 speed type 9 from a sierra, will match your crossflow
Ray
posted on 12/9/06 at 08:18 PM |
quote: Originally posted by mars103
hi mate,
Not quite, the newer engines such as the Zetec SE and the Duratec use a different bolt pattern.
The old school Cologne V6 does have the common bolt pattern, so that combination should work ok. The MT75 is a big lump though, compared to a type 9
(though obvioulsy stronger as well).
mars103
posted on 12/9/06 at 08:35 PM |
thanks for clearing that up for me
im going to live forever or die trying
johnjulie
posted on 12/9/06 at 09:05 PM |
It'll fit OK, but you'll need a different clutch, the type 9 has 23 splines, instead of the 20 spline one used in the 4speed.
Cheers John
JFDI
"Just F*****G Do It"
