Author: Subject: GRP scratch
iscmatt
Contributor
Posts 1929
Registered 30/3/06
Location York
Member Is Offline
Photo Archive Go!
Building: - BUILT - 2.0 pinto indy, Kent Cam, zzr1100 carbs
posted on 13/9/06 at 11:46 AM Reply With Quote
GRP scratch
BO**OCKS
i was just filing my grp and have put a massive scratch across the bonnet, is there a way of reparing the damage or not?
regards matt
pawgrp
posted on 13/9/06 at 12:02 PM Reply With Quote
Gelcoat repair
depends on the depth of the scratch. If you bring the bonnet to mk on saturday ( not this one ) and ask for me (paul) i will see if i can either buff it out or repair it for you
iscmatt
Contributor
Posts 1929
Registered 30/3/06
Location York
Member Is Offline
Photo Archive Go!
posted on 13/9/06 at 08:16 PM Reply With Quote
right cheers paul, are you at mk evary sat (when not at shows etc) as it wont be straight away that i bring the bonnet as i'm going to uni. maybe closer to christmas, can i have an email address to contact you closer to the time (or just ring mk?
cheers for your help
twybrow
posted on 20/9/06 at 09:44 AM Reply With Quote
As long as you can get hold of the gel coat, the repair should be easy! Very similar to normal paint work, but easier to finish!
