Author: Subject: rotary engine
rob126
posted on 14/9/06 at 09:15 AM Reply With Quote
rotary engine
what do you think about a rotary engined kit car??
am planning this but still not sure if it will work out
first time building something this big!!
joneh
posted on 14/9/06 at 09:17 AM Reply With Quote
A few people have used rx-7 donors. One of thems bound to post shortly.....
Volvorsport
posted on 14/9/06 at 09:19 AM Reply With Quote
yes please , ill have a twin turbo version , with a single HUGE garrett
the NA one like a 13b pull to 8000 rpm - just ignore the buzzer .
the RX7 twin turbo used all the companies experience in racing to provide a reliable engine - and morphed into the RX8 .
still 100k and your looking at a rebuild .
www.dbsmotorsport.co.uk
getting dirty under a bus
rob126
posted on 14/9/06 at 09:27 AM Reply With Quote
any idea about approximate performance figures with this engine in the kit car?
0-60? 1/4mile? etc...
Volvorsport
posted on 14/9/06 at 09:49 AM Reply With Quote
theres no reason , if the weight is low enough , to have a sub 5 sec 0-60 , depending on which engine you have .
11, or 12 sec qtr would be possible .
vorn
posted on 14/9/06 at 10:18 AM Reply With Quote
I looked into a 12a but didnt go that way because the eccentric shaft is in the middle of the motor and would of made mounting the motor hard , would have to have the motor very low in the car .
NS Dev
posted on 14/9/06 at 11:53 AM Reply With Quote
great engine as far as I know.
Big plus is it weighs nothing, big drawback is frequent rebuilds, but then they are simple to do. The engine is simpler to strip and put back together than a piston engine, but the seals are quite pricey.
know of a chap running one (12a non turbo) in a grasstrack special in the Evesham club that will completely thrash the V8 cars on a good day.
Think he runs a single weber 50 dcoe on it.
Also know of a twin turbo "turbo2" motor running in a mid engined metro that is awesome.
froggy
posted on 14/9/06 at 12:23 PM Reply With Quote
rx8,s are coming in with tip wear problems at 50-60k now so the old problems are still there but the turbo imports ive driven are a serious piece of kit
iank
posted on 14/9/06 at 12:33 PM Reply With Quote
You need to make sure your cooling is top notch they need plenty and really don't like being cooked.
Arthur Dent
posted on 14/9/06 at 04:19 PM Reply With Quote
Exaust heat and noise are the biggest issues. Followed by cooling.
'The major difference between a thing that might go wrong and a thing that cannot possibly go wrong is that when a thing that cannot possibly go wrong goes wrong, it usually turns out to be impossible to get at or repair.' Douglas Adams
chockymonster
posted on 14/9/06 at 06:34 PM Reply With Quote
and don't forget they use oil as a consumable!
rob126
posted on 14/9/06 at 07:04 PM Reply With Quote
y is noise an issue? we dont have MOT ever here. its just VRT... exhaust can be as load as u want...
rob126
posted on 14/9/06 at 07:07 PM Reply With Quote
so on the whole if the engine is rebuilt before it is put in, it has enough cooling, and is serviced regularly... it should be ok!
you think i can carry on with plans??? (engine im considering is the 13B found in the late rx7)
Jon Ison
posted on 14/9/06 at 09:31 PM Reply With Quote
This as to be the perfect locost donor, was on my list of possibles, discounted it now so share the link.
Arthur Dent
posted on 15/9/06 at 02:36 AM Reply With Quote
Ever hear a rotary without a muffler? Probably 2x as noisy as a piston motor. You really need super high quality exhaust system which causes packaging issues with a Seven.
leto
posted on 15/9/06 at 07:27 AM Reply With Quote
Link to Locost Sweden's gallery. Wish there were sound too
“I'm gonna ride around in style
I'm gonna drive everybody wild
'Cause I'll have the only one there is a round”. (J. Cash)
mad4x4
posted on 15/9/06 at 12:39 PM Reply With Quote
We had a guy up here looked at doing in Scotland. The lads gave up though lost intrest
Shame would hae been a quick car.
Warning a 13b can drink fuel !!
Scot's do it better in Kilts.
rob126
posted on 15/9/06 at 05:49 PM Reply With Quote
i can imagine that it drinks alot of fuel. car will only be used maximum once a week in summer. so wont be that much of a problem.
u know any approx performance figures of a rotary kitcar from that guy up in scotland?
