Author: Subject: rx7 donor
rob126
posted on 14/9/06 at 09:51 AM Reply With Quote
rx7 donor
what parts will i need from the rx7?
first time building something this big!!
mookaloid
posted on 14/9/06 at 10:07 AM Reply With Quote
I think there's a book on this maybe a bit of searching will help
rob126
posted on 14/9/06 at 12:05 PM Reply With Quote
tried to search but couldn't find anything.
any1 has any idea???
Lawnmower
posted on 14/9/06 at 03:10 PM Reply With Quote
Engine and gearbox!
rear diff?
dash, loom ecu? etc.
rx7 have a strange sterring, the rear on some mopdels has some sort of passive steering. I think there also a bit to wide.
You could try keeping the hubs and calipers though....
I hope to use it one day.
Arthur Dent
posted on 14/9/06 at 04:22 PM Reply With Quote
What Rx-7?
The 1st generation one have back axle, engine, tranny, and misc bits such as handbraker levers and such. The steering isn't useful as its not r&p. The front have struts so you need to convert or use something else. The 12A ones have very odd bolt pattern.
The 2nd generation is wider and has IRS. Does have a r&p steering though. Still struts up front. Engine is 13B - a bit tall with the stock FI.
'The major difference between a thing that might go wrong and a thing that cannot possibly go wrong is that when a thing that cannot possibly go wrong goes wrong, it usually turns out to be impossible to get at or repair.' Douglas Adams
rob126
posted on 15/9/06 at 08:24 PM Reply With Quote
Originally posted by Lawnmower
Engine and gearbox!
rear diff?
you may use it when its ready if you come to malta! shouldn't be a prob at all!
rob126
posted on 15/9/06 at 08:26 PM Reply With Quote
Originally posted by Arthur Dent
What Rx-7?
its the 13B i'm using from the new generation. being wide can be solved by using a different diff. not rx7 one i mean. the front may be a prob.
[Edited on 16/9/2006 by rob126]
Bart Vangampelaere
posted on 17/9/06 at 05:42 PM Reply With Quote
If you're using the 13B (second gen) as a donor, you can use engine and box, or even the IRS.
It'll depend on your track: the RX-7 has some 1440 (or close to that, must check) mm track width. Most stupid thing: track is wider front than rear. Looks strange on a Seven, I reckon.
It does have struts in front, so you'll need to work something out (or use different parts there). AAS (adaptive suspension and passive rear steering) can be delt with easily. Most likely, your donor won't have this anyway, but should it have: it can be removed.
Lawnmower
posted on 17/9/06 at 09:40 PM Reply With Quote
i did google for rx7 locost once. turned up a few homepages.
God luck
