gary gsx
posted on 16/9/06 at 08:58 PM |
Rad sizes
Could any body tell me if the micra rad is smaller than a polo one, reason being is i have a polo rad and its very tight in the nose cone (Luego
Locost).
Ive tried different ways of fitting it but no luck ![](/images//smilies/sad.gif)
Mark Allanson
posted on 16/9/06 at 09:16 PM |
The micra one is one of the smallest available, Mine fits with 3" gap all the way around. If you do fit one, change the rear mounted fan to a
front mounted fan from a Peugeot 306,405,406, it will save you load of hassle later
ian furness
posted on 16/9/06 at 09:27 PM |
radiator
try honda civic 18"x15" fits in well
omega 24 v6
posted on 16/9/06 at 10:09 PM |
Locost).
Snap with me also. It's tight but could be made to fit (JUST) however I'd prefer it to have a bit of clearance. I've been discussing
with a couple of people whether it would still work if it was in a vertical position. Would the outlets need to be at the top in order for it to be
bled??
Sorry if you think this is a thread hijack but it may help you with your problem as well.
gary gsx
posted on 16/9/06 at 10:13 PM |
We are all in it together matie the more people that answer the better ![](/images//smilies/bigsmile.gif) ![](/images//smilies/bigsmile.gif) ![](/images//smilies/bigsmile.gif)
Mark
What model micra is rad from just looked in your archive its fit better that my polo rad ![](/images//smilies/bigsmile.gif)
DavidM
posted on 17/9/06 at 02:09 PM |
I used a Micra radiator with a Luego locost nosecone and it fits fine. Kept the Micra fan too, with no problems.
Regards,
Proportion is Everything
