New Topic New Reply
Author: Subject: MK:s Wiring loom
Jonte
posted on 19/9/06 at 12:29 PM Reply With Quote
MK:s Wiring loom
How complete is the wiring loom provided by MK, is it everything except engine wiring?
Click it
shortie
posted on 19/9/06 at 07:15 PM Reply With Quote
It's actually a Vicky Green loom which is designed for a Pinto engine so basically it will do everything including the engine if you have a Pinto, if you have a different engine then you need to change\add some bits.
HTH,
Rich.
Jonte
posted on 19/9/06 at 08:34 PM Reply With Quote
ok....
Im actually thinking of a zetec with MS, so there´s no need for that part.
Probably easier to do the rest by myslef then.
BTW, whats vicky green...?
[Edited on 19-9-06 by Jonte]
Click it
iscmatt
Contributor
Posts 1929
Registered 30/3/06
Location York
Member Is Offline
Photo Archive Go!
Building: - BUILT - 2.0 pinto indy, Kent Cam, zzr1100 carbs
posted on 19/9/06 at 11:07 PM Reply With Quote
vicki green is the person who first made the loom.
i would say be careful though as i bought a loom from mk for my car, towards the end i had some problems so i spoke to Steve (mk wiring man) and he said it wasnt a vicki green! - it was i newer model with no plugs just wires.
however the only problem i had was with regards to engine wiring - you dont want this so it would probably be suitable for your aplication.
(just a warning for other mk pintos)
HTH Matt
Hursty
posted on 20/9/06 at 12:49 PM Reply With Quote
Hi
I bought a loom from Robin Hood which was cheaper than MK. It didn't have the engine bay included but that was fine for me as I din't have a pinto and was using the donor engine loom anyway. It cam complete with fuse box but no plugs just the wires. Worked ok for me and fits just fine.
matt.c
posted on 20/9/06 at 06:24 PM Reply With Quote
So is there anyone that does a loom especially for bike engine cars?
So i dont have to do anything to it but fit it to the car, plug everything in and go?
Zaphod
posted on 23/9/06 at 03:37 PM Reply With Quote
So the loom is complete with relays, fuses etc?
Jonte
posted on 24/9/06 at 04:25 PM Reply With Quote
that would be interesting to know
Click it
auzziejim
posted on 24/9/06 at 05:50 PM Reply With Quote
the vicky green loom has 4 fuses from memory and thats about it i think. i have a vg loom but it will be chopped about in the near future as i begin the task of wiring. all im using it for is the basic layout of the loom and wire
good job it was an ebay bargain
Hursty
posted on 27/9/06 at 12:09 PM Reply With Quote
Mine came complete with a small fuse box and fuses ( about six or so from memory), but no relays.
I used the flasher relay out of the donor car and bought a couple of new relays for lights etc from Ploevolt for abot £1.80 each
New Topic New Reply
